subdeck alternatives
Discussion in 'Construction' started by Evil Joker, Apr 18, 2008.
  1. Evil Joker
    Evil Joker Member
    what can i use besides 1/8 ply wood
  2. Kotori87
    Well, you could use 3/16" plywood, or 1/4" plywood. Or, if you're really stingy on weight, you could use 1/16" plywood...
    Does that answer your question, or are you asking about alternative materials to plywood? I've seen several other woods used, along with plastic (polycarbonate, I think), and one person even fiberglassed metal into his boat to use as a subdeck. Personally, I prefer aircraft-grade baltic birch plywood. I find it easy to work with, reliable, and it looks good, unlike scratched-up plastic or holy rusted metal.
  3. Evil Joker
    Evil Joker Member
    alternative materials to plywood plastic maybe but u can put wood skin on top. has it been done
    I'm using fiberglass sheet for my deck, but I'm using a 3/16" subdeck.
  5. Gettysburg114th
    I make make my subdecks out of spruce usually 48X3/8X1/4". I then lay a deck rim on top of the subdeck made out of 1/8X1/4" aircraft plywood. This method has worked for me for years and looks very clean when completed.
    Thanks,
  6. Lou
    Check out the cleveland build, I am using 1/8th for the sub-deck and top deck. It's inexpensive when you consider you can cut it with a jig saw or sissors (heavy-duty), doesn't need waterproofing (and no extra weight), and sands smooth.
