Submarine Surcouf
Discussion in 'General' started by NathanTindall, May 1, 2011.
  1. NathanTindall
    NathanTindall New Member
    Does anyone here have a 1:144 I400 or surcouf hull theyd wanna part with?
    also Kotori87 mentioned there are some extra dimension tolerences for subs, such as an added inch of depth below the waterline, just wanted to make sure i read that properly? Are there any other tolerances like this?
    Thanks
  2. NickMyers
    The tolerances for adding draft, weight, and dimensional errors all vary from ruleset to ruleset. You will really need to scour the rulesets of the group you want to play with and probably inquire about the existence of any 'house rules' if you intend to play with a club that is a subset of a larger organization.
    I would really advise meeting up with your local group and talking to them in person about some of the challenges that you'd face in building a combat sub before setting your heart on it. It may be something that you will enjoy more revisiting after some experience in surface warships rather than as your first build.
  3. KeriMorgret
    Seattle, Washington
    I believe there is a working sub in the WWCC. We can ask that individual to bring the sub to Maker Faire for you to look at, if you're able to come to Maker Faire.
  4. NathanTindall
    When is the fair and where at? Id definitly like to make it if i can
  5. NickMyers
  6. absolutek
    Ralph Coles made my Surcouf hull. You may want to inquire with him about a hull if you are so inclined. The one I got from him has had added depth to the hull so it is not 100% true to scale in that regard. I also have the new I400 hull from the mold Bob Pottle(?) made, and I can say it is indeed a fair bit larger (the surcouf was shipped inside the I400 hull).
  7. Kotori87
    There are actually several submarines in the WWCC. Click on the links to view them.
    I-400: This submarine was built in the 90's, and racked up an impressive list of kills (and a long list of sinks, too) before her skipper got a different job and left the club. It has not been heard from since. It used diving planes only and had a bow-mounted plunger to fire the torpedoes. Here's another view of the I-400.
    Surcouf: This submarine was also built in the 90's to compete with the I-400, and is virtually identical except it's French. her skipper still takes her out every once in a while, but what she really needs is an extensive overhaul with modern, leak-proof seals for diving planes, propshafts, and hatches. The image clearly shows two torpedo tubes, the firing plunger, and a rubber boot to help prevent ram damage. Here's a view of the Surcouf attacking. One downside to plunger-fired torpedoes is you need a target with enough inertia to press the plunger on impact. This little Maru was not torpedoed because the plunger bounced off.
    I-401: This submarine was built in 2007 by the owner of the Surcouf. It is similar in many ways to the previous boats, just with micro servos, an ESC, and NiMh batteries. He did not put powerful enough motors in, I-401 did not get anywhere near her allowed speed, and did not have enough downward thrust from her diving planes to dive. She had an impressive armament of four torpedoes forward, plunger-activated. She saved my bacon in the one battle she participated in, when a kamikaze charge by her distracted an Allied Mogami from finishing off my battered cruiser. She took the hit instead, and sank. You may be able to buy this ship from her owner, if you show up to several of our battles.
    I-402: This surface-running submarine is so terrifying that no photographer has dared take pictures of her. Actually, her kure-green paint is an effective camouflage so she's very hard to spot until it's too late. Wait... I DO have a photo with a blurry I-402 in the background. She was completed near the very end of last year's battle season Despite not being able to dive and only mounting a single torpedo tube, the I-402 has racked up more kills than any previous submarine and has taken only one single hit in return. One reason for this is that her torpedo is RC-fired, not button-fired, so she can hit targets up to two feet away.
  8. Kotori87
    The Maker Faire
    is on May 21st and 22nd in San Mateo, CA. We (the WWCC)
    will be building a shallow pond there so we can battle. It's a good chance to see what we do, meet some of the guys, and see a whole lot of other cool stuff while you're at it. I would also recommend, however, that you come visit
    some of our other battles
    as well. At other battles we won't be quite so busy, crowded, or hoarse, and you'll be able to get a much closer look inside our ships and a more detailed description. It also shows dedication, which goes a long way towards convincing others to sell their precious submarines or hulls to you.
  9. NASAAN101
    Guys,
    How do you arm them??????
  10. NathanTindall
    Thanks for the pictures. @kotori87, if i added an inch of depth ans say a half inch to an inch of width, do you.think that would be acceptable in your group?
    thanks
    ~nate
  11. Kotori87
    Nathan, we are allowed to add up to an inch depth, but width still has to be within 5% of scale. So I don't think you could add a half inch to the width. Building a Surcouf within the WWCC ruleset is entirely do-able, you just need to spend enough time planning and laying out the hardware so it all fits nicely.
    Nikki, our submarine "torpedoes" are actually 1/4" steel ball bearings, the same as what our biggest battleships shoot. Each shot is about twice as big and eight times as massive as the bbs you're used to.
  12. Anachronus
    On the I-402 is the one tube submerged or above water? How far with a 1/4" shot effectively travel through water?
  13. NathanTindall
    The surcouf is definitly the sub i am imterested in building, thanks for the info. Also, i wasnt sure how many of you have seen this: http://m.youtube.com/#/watch?desktop_uri=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3Dqqs1jaM-nW4&v=qqs1jaM-nW4&gl=US a video of the surcouf
  14. Kotori87
    The I-402's single torpedo tube is about 1/8 inch above the waterline, angled down just a degree or two. It will touch the water about 8 inches out, then tunnel for a few inches as it skips back up. It can hit and penetrate the armor on an average high-sided WWII battleship up to about 2 feet away, beyond that the torpedo passes over the penetrable area. While not a knockout punch by itself, the I-402's torpedo has a very high probability of causing flooding, which is deadly to a ship that's already been worked over by other warships. It has proven especially effective against the popular Silverfish-class tramps in the WWCC, which normally rely on their low freeboard to protect them.
    Nathan, linkie no workie. Can you send a simpler version of the link?
  15. KeriMorgret
    Seattle, Washington
  16. NathanTindall
    @Keri Morgret, yes that was the video link, thankyou for posting that, idk why my browser was giving me the bad link...
    I thought it was pretty awesome actually being able to see a video of the Surcouf, considering theres prolly not that many videos of it in existance...
  17. phill
    phill Active Member
    A few fiberglass Surcouf hulls were made many years back. I think Bob Pottle may have gotten his operational. I have a plan to build a dynamic diver without guns. Every time I take that hull down off the wall, I scratch my head and wonder how I am going to get enough stuff in that hull. My most recent build was the Mogador, a French destroyer leader and it was hard to do well. The submarine is about half as wide...
    Start with something closer to 15lbs for your first ship!
