Suffren Build
    I am going to laser-engrave 'bumb' on my BBS for Nats, so that you will have 'bumbs' in your ship. :)
  2. Beaver
    he he, very funny! :) Besides, how's your 28sec Evstafi supposed to catch, let alone shoot at my 23 sec cruiser? ;)
    Beaver
    I don't think you're faster than my BBs, and you'd be surprised how things happen on the water :) It's not all straight-line speed nor all maneuverability. You'll see :)
  4. Beaver
    Yeah, I think there are going to be lots of things I'm going to see in battle that I wasn't expecting. :) Marked a 1/4" line on the plywood. Used a very old tool to do it, which will be shown tonight. ;)
    Beaver
  5. Beaver
    Didn't get to cutting the cap-rails today. :( Went for a walk earlier today, and when I came home, I came down with a nasty headache. Ever since then, I haven't felt like doing anything related with a saw. I haven't felt like doing anything for that matter. :) But, I did get to marking the first line.
    So here are those promised photos.
    So here is my very old tool. :)
    I adjusted the scribe to 1/4" and then ran it along the edge of the plywood. After that, I took a well sharpened pencil and made it easier to see the line.
    And here is a photo of the Baltic Birch I picked up at a local wood store.
    And now I think I'm going to go lay down and try to shake off this nasty headache.
    Beaver
    Classy! I've been meaning to make one of those. they have so much more class than the stainless steel one I'm using, which is good and accurate but soulless.
  7. Beaver
    Thanks, although I like the old design, I think one of these would be neat. Sort of like stepping up one more class in "classiness". :) The headache went a way last night, so I should be able to start cutting cap-rails later today.
    Beaver
  8. SteveT44
    My 22 sec Vichy Mogador will herd you towards him! ;)
  9. Beaver
    Ah, sort of like a sheep being led to slaughter. :) I wonder how much the Russians paid you. ;)
    Beaver
  10. Beaver
    Got one 5ft section of cap-rail cut today. It was a lot of work for a small prize. I started out trying to use my big scroll saw, but it proved too difficult to move the plywood accurately by myself. Loss: 2in of wood.
    Next attempt/success was with a jig saw. Worked OK, but left a uneven edge on the rest of the board. So tomorrow I'm going to try using a table saw. Hopefully that will solve all my problems.
    How do you guys cut your cap-rails?
    Beaver
  11. Tugboat
    I lay the 1/8" ply on top of the hull, and trace the hull outline, then cut that out, cutting a little wide, then sand it to fit properly on the outside, then lay out the 1/4" line and cut it again on the inside. This also gives you a deck that fits the caprail. If there's a step that makes it easier, just do one part forward of the step, and one part aft.
  12. Beaver
    I don't know why I didn't think of that before. :) I know that the bow step would be easier to do that way, but what about the stern step. Would it be easier doing the way you suggested, or the way Mike did it on his Bearn?
    Beaver
  13. Tugboat
    For the stern step, I just butt the plywood up to the step and trace. Nothing fancy there.
  14. Beaver
    No, I'm talking about the method of cap-rail. Would it be easier to cut 1/4 cap-rails and glue them on, later tracing out decks, or the way you suggested?
    Beaver
  15. Tugboat
    I think it's easier the way I do it. I'm sure there are other skilled builders who do it a different way :)
  16. Beaver
    One down, one to go......
    Beaver
  17. Beaver
    Cut out the stern deck today. I'll post pictures tomorrow, but I wanted to know if it is better to waterproof the cap-rail before I secure it, or after?
    Beaver
  18. Tugboat
    I epoxy it down to the subdeck, and waterproof the whole hull together.
  19. Beaver
    Ok, that's what I'll do then. What's the best way to waterproof decks, epoxy?
    Beaver
  20. Beaver
    Photos are here!!!:D
    Tomorrow, I epoxy the decks, and possibly epoxy the caprails as well.
    Beaver
