Suffren Build
  1. NickMyers
    I see threadlocker in your future
  2. Beaver
    Indeed.
    Glad to hear it was useful :)
  4. Beaver
    Heh, just realized I never did post any pics. I'll have to update this thread after this hectic week is over. :)
  5. Beaver
    In preparation for the fall regionals, the solenoids get rewired. Much nicer and cleaner than the previous setup.
    Nate G and NickMyers like this.
  6. SteveT44
    Looking good. Now you just have to refinish that floor! :laugh:
  7. NickMyers
    i think that's a table
  8. Nate G
    Nate G Well-Known Member
    Bradford, PA
    nicely done. I am a big fan of modular systems and that is well built.
    much as I love my powerpoles, I will be going to XT30's for solenoid control.
    Tip of the hat to Dave Ranier. his new Biz build looks fantastic!
    (why do I mention that - he uses the small XT connectors on his solenoid control circuit and it is well laid out and neat. Something I have at times failed at. someone once told me, you don't have to invent everything, you just have to know how to copy_right :)
    Beaver and kgaigalas like this.
  9. kgaigalas
    kgaigalas Well-Known Member
    Grand Rapids, Michigan
    HOW TRUE
    Too many great ideas/people in this hobby.
    I have put my twist in my boats but I have not invented anything.
    If you need help ask for it, it is out there!!!!!
    Kas
  10. Beaver
    After about two years of combat, Suffren could use a refit. She ran and battled well, but now with other ships ready to take her place on the front lines it's time she had some improvements. Basically, some newbie mistakes need to be fixed and a couple things could be improved.
    So this is how she sat at the end of the 2016 battling season. She had just been battled in the IRCWCC fall regionals and did quite well.
    Some photos of the internals. My building style wasn't quite perfected with this ship so it's a bit of a rat's nest in there. Hoping to have things neater when it's all done.
    To start, all the internals were removed except the motor and the rudder servo.
    I then de-sheeted her in preparation to move the hard area up. When I first built Suffren I guessed my waterline too low and hence marked my "1 inch below the waterline" for the hard area too low as well. My plan is to use balsa blocks to move it up and then fiberglass over it.
    You can see how low the hard area is compared to the waterline.
    It appears that I might not have waterproofed the underside of the subdeck very well during construction as the wood was a little dark and the surface cracked in places. It sat in my basement all winter and dried out, so I gave the whole underside a coating of epoxy to seal it.
    So that's where she sits now.
    Some of the things I want to do during the refit:
    Probably build new decks, build up some of the ribs so they are flush with the subdeck (newbie mistake), clean up the wiring, mount more of the internal components versus just having them sit in there. That's some of it. I'm sure there's more that isn't coming to my head right now.
    But anyway, she is well on her way to being a combat ship once again!
    Enjoy! :)
  11. GeekSpeed
    GeekSpeed Active Member
    SoCal
    I have a Foch I scratch built that needs a major refit as well. I am doing the same thing you are, however, which is getting another ship online first before I go back and fix all of the rookie mistakes.
    Beaver and Lou like this.
  12. Beaver
    Very nice build! Looking forward to seeing the refit. It will be interesting to compare setups.
  13. GeekSpeed
    SoCal
    Thanks! Mine is much more old-school because that is what I had lying around. I am debating going solenoids, however, but I need to learn a lot more about them.
  14. Beaver
    Solenoids are nice. They're faster than poppets and a little easier to set up. And the Spartans don't cost much more than a poppet setup. If that's what you're looking to do, the guys here can walk you through the whole process.
    Is that a BC hull?
  15. GeekSpeed
    SoCal
    Ok, cool. Maybe I will post over in the weapons and pnuematics section. I actually scratch built Foch using the French Arsenal plans. I'll have to post some interior shots.
  16. Beaver
    Yeah, I'd like see inside. :)
