Suffren Build
    After I survive this battle weekend :)
  2. Beaver
    Can't wait to see it! Good luck at your battle, and don't get sunk too many times.;)
    Beaver
    Only once so far! Having a blast!
  4. Beaver
    Ok, nothing has really happened with the Suffren, except fixing the broken stern. The bow still needs fixed. When I actually took a look at it, I realized that fixing it like I was going to do wouldn't work. It's broken right at rib #1, and if you look in the previous pics right after rib 1 the keel starts to slant upwards leaving me nowhere to glue on a support. I don't have any fiberglass cloth or epoxy so I was wondering if I could use Tite-Bond and some of that mesh fiberglass wall reinforcement stuff that comes in rolls to help hold the bow on and to reinforce it instead of cloth and epoxy?
    I hope I didn't confuse you with that question.
    Beaver
    **EDIT** I tried this method on some scrap plywood, and it seemed to work very well. I actually couldn't break the seam.:eek:
  5. Beaver
    Last night I ordered the balsa from National Balsa to finish the hull, so that should be here in about a week. I also have the bow together and glued, just need to let it dry.
    Got to go,
    Beaver
  6. Beaver
    Yesterday I marked the waterline.
    Using a laser to mark the waterline.
    This what I was talking about In that confusing question a couple posts back.
    And a " through the ribs" shot to wrap it all up.
    Enjoy the photos,
    Beaver
  7. mike5334
    Great idea using a laser to help set the waterline. :)
    I MUST HAVE ONE!!!! Seriously, that's a great idea!
  9. Beaver
    Thanks,
    It does make things so much easier. It took me about ten minutes to mark the waterline using one.
    Beaver
  10. Beaver
    This post is on how I made the rudders. This is the same method that Tugboat used on his Edger Quinet. ( I think that's how you spell it):D
    I used 1/4" ply wood, so I had a lot of sanding to do.:p
    I applied a little too much glue, but hey, it's better to have too much than not enough.
    This is a rudder that I finished already,
    Enjoy the photos,
    Beaver
  11. Beaver
    I have a quick question on hard area. The IRC's rules states that hard area can start 1 in below the waterline, on my Suffren's stern 1in below the waterline is below the keel.
    What I'm wondering is, do I leave that area penetrable, or can I fill the very bottom with 1/4 in balsa?
    Thanks,
    Beaver
  12. absolutek
    The hard area is 1" below the waterline or 45° on the curvature of the bottom of the hull. Whichever comes first. I believe there is a nice diagram of thos on the ircwcc rules page.
  13. Beaver
    So what you're saying is, if I was to take a piece of plywood cut on a 45° angle, where it touches the hull that area can be impenetrable?
    Thanks,
    Beaver
  14. absolutek
    Yeah. I use a 45° triangle.
  15. Beaver
    Ok, thank you, Absolutek! my balsa should be here today, so I wanted to know.
    Thanks again,
    Beaver
  16. Beaver
    I have one more question, what is the scale waterline for the Suffren? I have mine marked at 1 3/4 in from the ground, and wanted to make sure that it's right before I make anything permanent.
    Beaver
  17. absolutek
    looking at the french plans its about 1.5-1.7" of draft. no idea what kind of loading that is though.
  18. Beaver
    Yeah, I think I'm just going to go with 1 3/4in. If I'm wrong, I'll have a lot of sanding to do!:sick:
    Thanks Absolutek,
    Beaver
  19. Beaver
    Um, I have another question about hard area. Using a 45 degree triangle I marked the hard area, but in some places the hard area is higher than the waterline.
    So which do I go by , the waterline or the 45? Or maybe I did something wrong?
    Beaver
  20. absolutek
    the waterline doesn't figure into it. Just make sure the deck is level when marking it.
