Suffren qc build
Discussion in 'Warship Builds' started by nativecaptain, Jun 4, 2017.
  1. nativecaptain
    nativecaptain Member
    Hey been slowly getting back to it.
    Beaver and NickMyers like this.
  2. nativecaptain
    I kinda lost interest for a while when I couldn't fix the keel mess up. It better now
  3. djranier
    Good to hear, you should of seen the first wood hull I tried to make, used a set of Golff plans, the ribs were not even close, but I did not check them before I cut them out and tried to assemble it. Went right into the trash, lol.
    nativecaptain likes this.
  4. nativecaptain
    I have already trash one hull. So would like to finish this one.
  5. Logan Gyre
    Logan Gyre Member
    Switzerland
    When?
  6. nativecaptain
    Hey Everyone,
    Well cleaning out the basement I stumbled on this old warship. Been working on the hard area of suffren for the last week.
    bsgkid117 likes this.
  7. darkapollo
    darkapollo Well-Known Member
    Carlisle PA
    Good to hear! Anything we can help with?
  8. nativecaptain
    Right now, not really doing the bottom section. Then planning on moving superstructure.
    Need to get electronics and cannons.
  9. nativecaptain
    Working on blocking out the bottom. Having some difficulty with the stern, getting the 1/4" balsa blocks to fit. Worked on the superstructure this weekend made some nice progress.
    Systems
    Hull - need to figure out sheeting.
    Propulsion- I have stuff to make props, stuffing tunes and rudder. Including one motor and service
    Control system - need battery,charger, Controller system.
    Canons have nothing. May run with no guns for a bit.
    Ballast - got several pounds of lead if needed
    Beaver and darkapollo like this.
  10. nativecaptain
    Quick update.
    Got the balsa blocks in and finishing the sanding on the ship.
    Still have to fill in the bow.
    Fixed the bowing in the keel, but the bow has drift about a 1/4 from the center line at the keel.
    I'm thinking to fix this is to make two cuts in the balsa blocks three ribs down from the bow. on one side placing a shim and trying to close the cut on the opposite site.
  11. Beaver
    Nice work! That pic reminds me of when I was building mine.
