Test Buttons on DX6
Discussion in 'Electrical & Radio' started by S-116, Jan 15, 2018.
  1. S-116
    S-116 New Member
    Athens Ga.
    Crew
    I done the easy part and installed 4 buttons on my DX6 now for the hard part how to test them
    I was thinking just to connect a rec servo push a button the servo arm would turn once and return
    I have had the Radio on and no smoke
    Thanks' for any help
    Bill
  2. SnipeHunter
    Sounds like a good plan. Also be sure to test them with whatever firing board you're using once you've done the initial test, sometimes you'll need to adjust the trim or the throw in the radio software to get proper activation. Good luck.
  3. S-116
    S-116 New Member
    Athens Ga.
    Thanks Snipehunter
    I did not think of that got one from BC for my PE or Scharnhorst or both Radio will be used on all my Attack ships
    Have other Radio's for my Sailboats and Paddle Wheelers
    Again thanks
    Bill
