The Malaya Build
Discussion in 'North Atlantic Battle Squadron' started by ChuckR, Apr 27, 2008.
Thread Status:
Not open for further replies.
  1. Chris Easterbrook
    Hope you can get your stuff soon. What do you need Chuck? If I have any extra I would be will to donate it. I don't have alot of extra stuff but you never know.
  2. JRodgers
    JRodgers Member
  3. JRodgers
    JRodgers Member
  4. JRodgers
    JRodgers Member
  5. JRodgers
    JRodgers Member
  6. Chris Easterbrook
    Good progress Chuck.
  7. Craig
    Craig Active Member
    Ok Chuck, before you attach the battery tray, be sure to attach the blue stuff to the hull first. Then, cut out the plastic, sintra, whatever into individual strips exactly where they are now and put them into the spaces for your batteries to rest on. You will finish with a channel for the water and four pieces of plastic in between all the spaces... pretty much where it sits now. Be sure to drop you batteries in when you are attaching the tray in the beginning to ensure a nice snug fit.
  8. ChuckR
    ChuckR Active Member
    Not sure how many servos I need for my guns but I have two coming when our radios show up. 2 universals. 2 cannons and all fittings for the cannons. 2 Batteries. That's all I can think of but if there are other that anyone can think of let me know.
  9. Chris Easterbrook
    Let me know if you need any servos, if Jay does not need any of my extra fittings there yours Chuck.
  10. ChuckR
    I've got 4 guns. Do I need 1 servo per gun or can I use a single servo between 2 guns.
  11. Chris Easterbrook
    How are you planning to set her up? what guns going where?
  12. crzyhawk
    Assuming you are using dual sterns and two sidemounts, you'd need two servos to handle that. One servo will handle the left and right sidemounts: Left will kick the poppet for the left sidemount and right will kick the poppet for the right sidemount. The second servo will control the dual stern guns, and requires a different type of poppet IIRC off the back stick. Front stick is usually used to switch your pump off/on.
    That's the standard for gun set up on a QE class battleship.
  13. ChuckR
    Two singles up front, one off each side and 2 singles off the back, one off each side. This what I was thinking.
  14. Chris Easterbrook
    You woul only need two servos one for the front guns and one for the aft guns. Chuck I would make the two guns aft a dual stern mount with the two single side mounts up front. This arrangement is a good all around set up.
  15. ChuckR
    I got one servo more servo today. Joy's radio came with one she didnt need.
  16. ChuckR
    There is also one coming with my radio when it gets here. Then I will only need 2 more servos for the guns.
  17. ChuckR
    If dual aft guns are the best way to go then that is what I will do.
  18. Chris Easterbrook
    We talk Chuck I going to have some extras
  19. ChuckR
    Let me know how much you want for anything I need. Been working on my servo tray and rudders.
  20. ChuckR
    She should atleast be on the wtaer by this weekend.
Thread Status:
