This Old Machine: Re-purposing an Engraver as a 3D Printer
Discussion in 'Digital Design and Fabrication' started by jch72, Jun 8, 2015.
  1. NickMyers
    I think thats a bit rougher of a lead than most use (for instance my O2 uses a m5 with a 0.8mm pitch. You should still be fine for layer heights though - .12 and .24ish mm layers are perfectly acceptable for quality on a toy boat for our needs. Your lack of fine control on Z though does mean you're going to have to work extra at making sure you've got your bed level and zero'd mechanically. I would see if I could make it work with what you've got though.
  2. jch72
    jch72 Active Member
    So I guess a better question would be what is the minimum layer height that can be printed successfully?
    I can work backwards from there to see what I need to do. I really prefer to do the lead screw once and be done with it, plus SDP/SI is discontinuing some of the nuts and lead screws of the type I'm using so I'd rather do it soon. I did find 4 small steppers in my garage that may possibly work for extruder drives.
    I'm listing the specs here so I don't have to do a search again: Japan Servo Co. KP35FM2-044 Bipolar 1.8degree 24V 8ohm 0.5Amp 90 g*cm detent torque 700 g*cm holding torque 1.45inch mounting hole diagonal .866 mounting boss diameter .197 X .9 shaft Body: 1.375 square 1.05 long 0.32 lb
  3. NickMyers
    I've printed down to 0.1, but typically work around .2. I'm reasonably certain I could print thinner layers but don't see a need. Practical layer height is also a function of your hotend. Its a bit dodgier to try to lay down a .1 layer with a 0.6mm nozzle than it is with a 0.4mm. I've put together prints with 0.3mm layers as well. Visually at 2+ feet its all pretty much the same for a lot of parts.
  4. rcengr
    400 steps per inch is the full step resolution of the stepper and screw. But most stepper drivers will have micro stepping, commonly 1/16, so in this case your steps per inch will be 6400. I wouldn't change your lead screw.
  5. jch72
    jch72 Active Member
    Bad news for my pocket book, I got out the calipers and the screws are actually 7/16-8, an uncommon size that seems to cost 4-5X as much. I could replace all the lead screws with 10mm metric trapezoidal lead screws for about the same cost, not counting the nuts, but they won't fit through my lathe headstock so I would have to have somebody machine them. Maybe I can go smaller.
  6. jch72
    jch72 Active Member
    First piles of junk ordered - smoothieboard, 24V 20A power supply, spi thermocouple card, MK2B hotbed and glass, Generic J head, 6 inch Crap tape, eSun grey ABS filament, LCD.
    Still need to sort out the lead screws.
    I don't understand shelling out for the very nice Smoothieboard but then limiting yourself with a generic J-head? :) Why not an E3D?
  8. jch72
    jch72 Active Member
    Because I will be building my own hot tip at some point. And the design is very similar, E3D vs the generic, except that the generic has active cooling provided with a fan and is 50% cheaper.
    Now I'm really confused; the E3D has active cooling, and the J-head does not. There are some new all-metal J-head variants but they're basically the same as the E3D Lite hotend, which still has a PTFE liner.
    You are correct about the cost, it's pricey.
  10. jch72
    jch72 Active Member
    I dunno then, I guess I will find out how well it works when I get it installed. Really I think the idea of getting a consistent plastic melt inside a tube without introducing rotational shear to the plastic with a screw probably only works part of the time anyways.
  11. NickMyers
    What sort of feedrate can you achieve on those leadscrews&steppers?
  12. jch72
    jch72 Active Member
    0.5 inch lead. so 200 steps/sec = 12.7 mm / sec. Light motor loading would be 2000 steps/sec = 10 rev/sec = 600 rpm = 127 mm/sec. With acceleration control probably a lot more than that, maybe around 250 mm/sec. Guesswork until it is installed and running.
  13. Tugboat
    I would think that you've got plenty of feedrate with those numbers :) Most of my printing has been at 60mm/sec or less.
  14. jch72
    jch72 Active Member
    What limits your printer to 60mm/s? Carriage movement or extrusion speed?
  15. Tugboat
    I have experimented with faster, but the GT2 timing belt has enough elongation under load that I can see artifact on the printed object. It looks kind of like ripples at corners in the print. They can be smoothed out in post-processing and certainly wouldn't be visible from 10 feet on a combat model, but still...
    I had considered doing all-leadscrews on my i3 variant, but I wasn't sure about getting similar artifact from leadscrew inertia. But since I plan to use a smoothieboard on the i3 variant, I can take the stepper voltage up which could mitigate the artifact (if it would happen at 12V with leadscrews...) with greater motor torque.
    I already bought into redesigning the Z and X axes because I decided to use real leadscrews and nuts (on the Z-axis) vice the threaded rod that most printers are using these days. Changing out the printed parts of the Y-axis is fairly trivial at this point. X-axis parts aren't done being redesigned yet, so that wouldn't be a new burden.
    I don't know what the maximum extrusion speed on the RRP hotend is, nor for the E3D that will be on the i3 variant. Time for some research :) I do know that delta printers with J-head extruders are capable of very high print speeds with 0.5mm nozzles. My E3D hotend currently has a 0.4mm nozzle for finer detail; I want to do a gearbox that is entirely printed, apart from shafting and a few M3 nuts and screws to lock the gears to the shafts.
  16. NickMyers
    I run 50-60mm/s on my O2 with the e3d 0.4
    I can run faster, but I'm not sure exactly how much faster. Too fast on smaller parts and you just end up with a big gooey mess.
  17. jch72
    jch72 Active Member
    I understand about the gooey mess, plastic doesn't cool from above Tm to below Tg very fast. Insulating the nozzle and aiming a small fan at it from the top might help some, or might not be worth the trouble.
  18. NickMyers
    Generally you use a fan to cool PLA prints, but not ABS. ABS will firm up fairly quickly - in my experience a 10sec layer time is generally enough if your hotend doesnt radiate metric f*cktons of heat (very scientific number). Cooling ABS tends to lead to warping and delamination problems - problems I hoped to resolve by moving to pet-g, but since I can't reliably print that with my current hot end, I'll be trying HIPS next.
  19. jch72
    jch72 Active Member
    Got the last order made today, 8mm diameter 8mm pitch replacement lead screws. Will give a 0.04 mm resolution on full steps. So the only thing I am lacking now as far as parts on order is the pusher contraption for the filament.
  20. Tugboat
    After scratching some drawings on scrap paper at work today, I'm ordering two more 8mm leadscrews with the fancy brass nuts for them, so that I can move the X and Y axes with leadscrews. My i3 is relatively experimental anyhow, and I can always retrofit it with belts.
