Tirpitz build
Discussion in 'Warship Builds' started by joe thomer, Nov 20, 2011.
  1. joe thomer
    joe thomer Active Member
    Starting the build of the Tirpitz.
    hull cut out with 1/8 armor belt stringer.
  2. joe thomer
    adding strength and attach locations for BB protection.
  3. NickMyers
    Lookign good so far. I like the wood backing for the stringers and the little vertical pieces above them.
    What size motor are you throwing in this?
  4. joe thomer
    not sure what size it it, but it is big, came with the kit from strike models.
    think it is the same motor alex has in his bismark
  5. joe thomer
    installing drive shaft and motor
    ..[​IMG]
  6. thegeek
    The motor is a 6 volt Johnson hc970. They pull about 18 amps at 6 volts with a 2" or so prop.
  7. jch72
    jch72 Active Member
    What drive voltage do you plan on running?
    Ron Hunt
  8. joe thomer
    ron,
    going to use a speed controler..viber marine about 40 amps. Think that would be large enough
    thegeek
    thx for the info above.
    what size amp speed controler would you sugest?
  9. rarena
    40 amp might smoke.....
    I fried 3 of them
  10. jch72
    jch72 Active Member
    Depends on the voltage you run, the lower the voltage the higher the amp draw. I'm running a 25 in my Nagato powering 2 motors on 13.2 volts. That pulls 10-15 amps. We have 2 Tirpitz locally and have been experimenting with drive for a while. I think we settled on 12 volts with 2 Titan marines geared down about 2 to 1 and a 1 7/8" 5 blade prop, Vicious P could probably tell you more since one of the Tirpitz is his. I think he lost a 40 amp recently but it might have been previously damaged and only partially functional. I don't recommend using the bec on the speed control for anything, if you fry the bec you lose the speed control, and they are a little under powered. Castle creations makes a decent 10 amp and 20 amp bec that seem to be pretty durable.
    Ron Hunt
  11. joe thomer
    ron,
    using 6 volt, lead acid sealed batterys, at least two, maybe more depending on how the layout in the boat works outl
    the batterys in parallel, so the voltage stays at 6 volts.
    not planning on gearying down right now, using 1/1 that came with the kit.
    just read up on the bec...Battery Eliminator Circuit....yes, sounds like it is better to get a speed controler with out bec. then you will not have any noise between the reciever and motor voltage and both are isolated. they did say the new sc ones, are much better now and most of this problem has been eliminated.
  12. joe thomer
    picks of drive shaft layout and ready for expoying in motor support and shaft support.
  13. thegeek
    40 amp control should work fine. But the SLA batteries might have a hard time giving 18 amps for a whole hour (normal time for one battle).
  14. thegeek
    Also the motor mounts have to be bigger in foot print. Too small and they will torque and rip from the bottom.
  15. joe thomer
    motor mounts, yes I was wonder and thinking about that, due to the size of the engine. with this motor mount, a couple csk screw from the out side into the bottom of the motor mount should stregthing it more than enought. saw this idea from a build thread.
  16. joe thomer
    motor mount and shaft support expoyed in.
  17. daemond6
    daemond6 Member
    Looking nice - bracing behind the stringers is a great idea - first build thread I've seen using that.
    Daemon
  18. McSpuds
    McSpuds Vendor
    Louisville, Ky
    Yes I like the idea of putting wood back there...... Will be on my next build for sure. Good job!
  19. joe thomer
    drive shaft installed, used some glass for reinforcing
    the gelcoat chiped off during drilling, but fille it back in with expoy
  20. NickMyers
    Joe, are you planning on putting two pumps in this?
