Torpedo's
Discussion in 'Weapons & Pneumatics' started by WaterSide, May 19, 2011.
  1. Kotori87
    Sealing the magazine will improve efficiency, but it is not required. Still a good idea if you can do it, though.
  2. Kun2112
    Carl, Do you have a source/part # for that Tee fitting? I have not been able to find one locally. The closest i came was 1/4 OD compression on the ends with 1/8 NPT on the sides.
  3. Kotori87
    My local OSH carries T fittings suitable for a bb-caliber cannon. For larger ones, you'll need a different part. I'll ask my shopmaster where he got his.
  4. Kun2112
    The more I think about it the Arizona is really a single barreled, scaled down Indiana.
    Shouldn't the acumulator be lower pressure than the rest of the system? Shouldn't the poppet activating the MPA-3 be a MAV-3 rather than a MAV-2?
  5. Kotori87
    The answers to your questions are
    0) short of.
    1) sometimes.
    2) yes.
    Yes, the Arizona is a scaled-down Indiana. However, the Arizona was developed first, so it is technically proper to say the Indiana is a scaled-up Arizona cannon.
    For actuation, the important part is that there is enough force to open the valve. The important thing here is the ratio of the buna-ball valve's cross-sectional area (or MJV valve's cross-sectional area) to the actuator's cross-sectional area. If the actuator has more area than the valve, then you can have equal or potentially even lower pressure in the actuator than in the accumulator. If the actuator has less area than the valve, then you must have more pressure in the actuator or it won't be able to open the valve. in the case of the Arizona cannon, an MPA-3 has much more cross-sectional area than the MJV-2 valve, so it works just fine with equal pressure in both sides.
    For firing, yes you need an MAV-3 valve or SMAV-3 valve and NOT an MAV-2 valve. I have tried the MAV-2 valve and it doesn't work. What happens is you press the button, sending pressure to the actuator to fire the valve. With a MAV-3, it then bleeds that gas when you release the trigger. With a MAV-2, it doesn't bleed the gas in the actuator upon release, so the gun just keeps blowing air until you're out of CO2. that really sucks, so don't try it yourself.
  6. Kun2112
    I can drill out the Tee fitting to work for 1/4" easy enough, I just need a source/part #
  7. Kotori87
    I don't actually know a part number. It's just a basic T fitting from my local hardware store with 1/4 compression on the top and side, and 1/8NPT on the bottom. I will see if they have a part number next time I go there. Another option is to make your own from 1/4" brass tubing, then chop off some 1/8NPT threads from another piece and solder those on. You can see some examples here:
    http://www.queensown.org/armament/armament.html
    you can find a fine example of a soldered tube breech about 2/3 down the page, and other possible methods are shown as well.
  8. Cruiserbecruising
    Cruiserbecruising New Member
    What kind of torpedos are we talking about here..?
  9. DarrenScott
    These would be cannon, designed to substitute for a torpedo with a 1/4 inch ball.
    Not locomotive torpedoes, which have another discussion devoted to them.
  10. Cruiserbecruising
    So basically, it's just a cannon.....
    Great.
  11. NickMyers
    Yes
  12. Knight4hire
    Knight4hire Active Member
    Yes, a single shot cannon.
    Must return to port to reload.
  13. Cruiserbecruising
    So why does it have to look all fancy and stuff...?
  14. NickMyers
