Traxxas waterproof servo
Discussion in 'Product Review' started by Kotori87, Aug 31, 2008.
  1. Kotori87
    Several months ago, somebody on the Big Gun email list pointed out that Traxxas had released a servo with o-ring seals that was labeled "waterproof". Rob acquired one of these servos, and gave it to me for testing. It worked fine in 3 feet of water, but the deep-water test was inconclusive due to failed receiver waterproofing. I then installed the servo in my miniature merchantman, saying "we'll test it when it sinks". Well, it finally happened. USS Silverfish, un-sunk since I installed the Traxxas waterproof servo, finally got sunk. They shot over it, they shot under it, they even shot into it, but nothing seemed to work. Finally, they ran it over with a battlecruiser, and that put the Silverfish down for good. Or did it?
    My tiny little transport sank in approximately 8 to 10 feet of water, and stayed on the bottom for about 20 minutes before a time-out was called to recover sunken ships. When I got it back on the bench, I dumped out the water, cycled the power switch, and ran a quick systems check. Everything worked fine. The skotchkote-covered receiver was great, the geared 280 motor was fine, and the traxxas waterproof servo was working just like normal. I was back on the water within 5 minutes of getting on the bench, no maintenance required. USS Silverfish then went on to complete at least 10 more cargo laps, scoring many points for the Blue-Flag team.
    Based on these results, I give the traxxas waterproof servo an "A" for its combat test, and I intend to use it in all future ships. They also have a sub-micro version suitable for destroyers. I can't wait until they come out with a micro metal-gear version for cannon depression :D
    Waterproof "standard" servo:
    http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXTKL0&P=ML
    Waterproof "sub-micro" servo:
    http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXTKL3&P=M
    -Carl
  2. Bob Pottle
    Carl,
    Is it compatible with Futaba radios and connectors? Couldn't tell form the link.
  3. jadfer
    Ha I was going to post asking about it today. Should we do anything more to it than stock? What about the oring on the spline?
  4. Kotori87
    I didn't do any modifications to it. The spline fits Futaba servo arms.
  5. Bryan
    Bryan Member
    For those in Canada Great hobbies carries them.
    http://www.greathobbies.com/productinfo/?prod_id=TRX2075
    Seems to be a great idea
    Futaba connectors but easy to switch to JR if needed
    Here is the way if any of you need end connector changes
    most with trimming will fit physically,just check the pins
    before plugging in, check the link they say it better than
    i will ever be able to
    http://www.fatlion.com/sailplanes/servos.html
    Bryan
  6. warspiteIRC
    warspiteIRC RIP
    Annapolis, MD
    It already has an "O" ring on the shaft (internally).
  7. Kotori87
    And o-rings around the bottom, and middle, and wires, and even around the screws. What will they think of next?
  8. Powder Monkey
    I would say its about time [^]
  9. Kotori87
    I'm hoping they come up with a metal-geared micro version, suitable for the depression servo on Big Gun battleships. Standard servos are great, but only for the ships with really big barbettes.
  10. jadfer
    Carl,
    Since you first bought the servo how many times has is gone beyond the traxxas '3 foot waterproof' threshold, and for how long each time?
    Thanks,
    Johnny
  11. Kotori87
    It's been 8 feet under at least 3 times, with immersion times varying between 5 and 30 minutes.
  12. Evil Joker
    Evil Joker Member
    just received email from traxxas l
    Our waterproof components are waterproof at 1 ATM.
    ATM = depth of water of 33 feet.
  13. jadfer
    Awesome. I bought 3 but I have been told to add diving grease to them anyway. Has anyone else 'water-proofed' the water proof servos?
  14. Evil Joker
    Evil Joker Member
    i have not 'water-proofed' and have sunk at lest 10 times with no problems
  15. BoomerBoy17
    i have one, thanks joker for the info. my rudder assembly will thank you.
  16. phill
    phill Active Member
    I think the grease is a good idea...
    1ATM is sea level, 2 ATM's is 33 feet of seawater. You still have 1ATM sitting on top of the water...
    Scuba Phill
  17. Evil Joker
    Evil Joker Member
    opps. so maybe there good at 5 to 8 . i sink about 5 feet all the time and have had no problems
  18. phill
    phill Active Member
    There is much to be said about keeping your ships in 5ft of water max. I've pulled one up from 12 feet and that was tough. The problem is keeping that much weight up while you are trying to swim. Not that I want to loose the ship, but I really don't want to lose a captain.
    When we battle in deeper water, we insist on floats for the ships and use a rowboat for picking them up!
  19. jadfer
    Does that mean that in Denver you can sink and not get wet?
  20. phill
    phill Active Member
    I'm in Olympia, a pretty short distance out into Puget Sound will get you into 600 to 1000 feet of seawater. I'd rather battle in the settling ponds. They are gravel bottomed and usually 4-6 feet max!
