Treaty Bismarck
  1. Gettysburg114th
    Mike,
    You know the water in the pond is not that clear....
  2. crzyhawk
    No worries, I'll prop wash the mud off your superstructure when I sail over you.
    Crikey, Bob, I think there's something wrong with your bloody ship today!
  3. Gettysburg114th
    We don't allow prop washing in Treaty....
  4. Gettysburg114th
    Started sealing the s/s today. Hardest part was keeping the temp up in the garage.
  5. Gettysburg114th
    We got the ok from the Fire Dept to use their pond again this year. I talke to the wife and she and I think it would be nice to give them a donation this year.
    I worked on more s/s today and will start mounting the guns that will be used to pound on the Alied Fleet this year. My VDT will be built over the battling season with hops that she can be loaned out at events.
    I will start posting pictures again soon.
  6. Gettysburg114th
    Hey guys,
    I am looking for a source for 7.2 volt 10 amp NiMh batteries?
    Thanks,
  7. BoomerBoy17
    http://www.shopwiki.com/search/7.2+volt+NiMh+RC+Car+Battery
    might help you.
  8. Gettysburg114th
    Thanks Boomer
  9. BoomerBoy17
    No problem, what did you want to use it for?
    Im using 2 of the 9th one from the top, looks good so far, for my spee.
  10. Gettysburg114th
    WOW
    Over 8500 views for this build! Anyone know where the directions are to post pictures? Maybe I should start posting to this thread again?
  11. NickMyers
  12. Gettysburg114th
    Thanks Klink, I mean Nick!
  13. Gettysburg114th
    Hello all,
    I managed to get the Kirishima mounted to the building board and epoxied the inside and the outside of the Bismarck superstructure. A light sanding and it will be ready to paint. I also glued in the bump stops in the Bismarck hull. These are aircraft plywood that is used to keep the batteries and the waterproof box from sliding around in the hull.
    I hope to have Bismarck on the water in two weeks. After sea trials I will cut the windows.
    More later,
  14. Gettysburg114th
    I worked on getting the shape of the main turrets right last night. I have one turret the way I want it and a second just about right. I filed them to get the angles nice and crisp.
    Thanks,
  15. Gettysburg114th
    The Bismarck superstructure is complete less the secondary guns. It was just taken out back to let the paint dry.
  16. Gettysburg114th
    Just wanted to update the progress on Bismarck. Or should I say Tirpitz? I have decided to change the name of the ship to Tirpitz so that Roland can continue to call his ship Bismarck. I added some superstructure to help pull off the name change. There were a few minor differences in the two ships.
    The superstructure is complete less the secondary turrets. I will hold off to do them until after the ship is battle ready. Wiring is at least halfway complete. I need to run the negative wiring. At that time Tirpitz can hit the water. I still need to hook the plumbing up to the guns which are all mounted. That should be a nice Saturday afternoon job. After trials I will cut all the windows.
  17. BoomerBoy17
    Isnt the tirpitz longer? would it still be leagal if it wasnt the right length
  18. Gettysburg114th
    Boomer,
    Yes it is longer. I have a Ralph Coles hull from Canada which is a Tirpitz hull. I think it's something like 832 feet.
    Thanks,
  19. crzyhawk
    I'm pretty sure that the difference in length is with the allowed +/-
  20. Gettysburg114th
    You are correct Crazy.
