Trivia IV
  1. thegeek
    http://books.google.com/books?id=b2zipv8_yQUC&pg=PA1175&lpg=PA1175&dq=epoxy+liver+toxicity&source=bl&ots=YojMB0bMps&sig=Lr8Ex4Z-bwbeLyxR8HKTAqoXDxo&hl=en&sa=X&ei=2M_CUqSrBaLjsAT6zYHAAQ&ved=0CDQQ6AEwAA#v=onepage&q=epoxy%20liver%20toxicity&f=false
    Never believe the label on a product is totally true, and while some resins are called safe when cured and others aren't is suspect.
    Either way just be careful when you grind them.
    How do you boys take the skin off your boats? I use a heat gun and a open window and never grind if I can.
  2. Beaver
    So who gets it? I'm totally oblivious as to who's right or wrong.
    Beaver
  3. absolutek
    You can go ahead Beaver. I think the moral here is to use proper PPE (personal protective equipment) for whatever one you might use, because they are all dangerous in their own way.
  4. Beaver
    Aright, here is today's question.
    What do these three ships have in common other than that they were sunk, and that they all were part of the Bismark chase?
    DKM Bismark
    HMS Cossak
    HMS Ark Royal
    Beaver
  5. NickMyers
    They all have the letter 'k' in their name?
    They were all torpedoed?
    They all fought in WW2?
    They were all ships?
    They had sailors on board?
  6. Beaver
    Though those are good answers, they're not what I had in mind. Keep guessing!
    Beaver
  7. NickMyers
    Fine, you want to play it that way then.
  8. Beaver
    Who's that? To me, that is just a cat. :)
    Beaver
  9. NickMyers
    Another thing you did not ask for!
    You're welcome to check the filename.
  10. Beaver
    Ok, Nick, I'll give it to you. They were all the home of Unsinkable Sam, AKA Oscar the cat.
    You're up.
    Beaver
  11. Beaver
    Nick?????
    Beaver
  12. Murchisonge
    Murchisonge Active Member
    Houston, Texas
    If nobody minds, I'll throw up the next question. Can you name the only US Navy destroyer to have the following dimensions and armament? This ship was 440’ 3” long with a beam of 38’ 1” with 8 X 4”/65 guns, 37 X 25mm anti aircraft guns and 4 X 13mm anti aircraft guns?
  13. SteveT44
    DD-934, former IJN Hanazuki
  14. SteveT44
    Any dancing with the stars fans out there? If so, this one will be easy for you! :p
    This caged beauty danced the seas to her own tango.
  15. SteveT44
    I see there's no action on my trivia challenge so I'll update it a bit.
    This caged beauty danced the "southern" seas to her own tango.
  16. Murchisonge
    Houston, Texas
    Would it happen to be one of the Rivadavia CLass battleships from Argentine?
  17. SteveT44
    Ding! You win.:laugh:
  18. Murchisonge
    Houston, Texas
    That was a good question. Ok, what us infantry unit had a gold swastika as their emblem at the start of World War 2?
  19. Murchisonge
    Houston, Texas
  20. Beaver
    45th Infantry Division?
    Beaver
