U.S.S. Des Moines
Discussion in 'Warship Builds' started by dmiowac134, Nov 22, 2014.
  1. NickMyers
    Have to agree with Chase, that looks reallllly low. If the weight is right, how much of the upper hull did you remove?
  2. dmiowac134
    dmiowac134 Active Member
    Readlyn, Iowa
    I didn't include the weight of the hull, didn't think about that, I cut 3/8 off of the top of the hull.
  3. absolutek
    Running it heavy like that will ruin your already bad turning ability. I have one of those hulls too it probably weighs a couple of pounds easy.
  4. NickMyers
    This is a Battlers Connection hull?
  5. dmiowac134
    Readlyn, Iowa
    That's not good, thought I was doing it right. Yes its a battlers connections hull.
  6. absolutek
    The good news is that it's easy to fix. You'll probably just have to cut the windows a little bit further down.
    A certain amount of OOPS is expected in a build :) Luckily, your OOPS is easy to deal with and requires no special finagling.
  8. NickMyers
    Back to your earlier question. Next I would fit the subdeck, but not attach it. Mark the location of the turret(s) your guns will be in in the bottom of the hull, and then start the layout of your propshafts and motor mounts and pump. From there you can lay out the rest of your internals.
  9. dmiowac134
    Readlyn, Iowa
    Thanks NickMyers and Bob H for your insight. I'll start working on the propshafts this weekend. Here is a couple of pics of the windows.
  10. NickMyers
    How are your prop shafts coming along?
  11. dmiowac134
    Readlyn, Iowa
    Not good, haven't started. Switched to 3rd shift after wife got a job. Taking care of my son during the day. Hopefully start to work on it during Christmas shutdown. I do have a question about the width of the hull. The plansI have are alittle hard to read.
  12. NickMyers
    IRCWCC shiplist marks the scale beam at 6.33inches
  13. dmiowac134
    Readlyn, Iowa
    Ok thanks, ordered different plans from strike today. I'm thinking about ABS for super structure.
  14. dmiowac134
    Readlyn, Iowa
    Will work on rudder/propshafts tomorrow.
  15. dmiowac134
    Readlyn, Iowa
    Got rudder hole drilled out, went to do the propshafts, realized that the props I purchased from BC are 2.5. Going to order 1.5's.
    Brian K and I did superstructure for our Badens from 1/8" ABS sheet. It's effectively bulletproof.
  17. dmiowac134
    Readlyn, Iowa
    Thanks Tugboat, that's what I was gonna try, just need to order some, any suppliers in mind?
  18. Beaver
  19. dmiowac134
    Readlyn, Iowa
    I looked at the prop shop and I'm confused on which prop's to purchase? Help please!!!!
  20. Tugboat
    Props I will leave to guys with more time in Des Moines's...
    The ABS sheet I got from McMaster Carr.
