U.S.S. Des Moines
Discussion in 'Warship Builds' started by dmiowac134, Nov 22, 2014.
  1. Bob
    You want the Kort Nozzel props at 1.5". The part numbers are KNP/1515/4/RH/BR and KNP/1515/4/LH/BR. You can tell them want to make the shaft bore. I assume you are 1/8" or maybe 5/32".
    A couple things to lookout for. You need to solder them on the shafts. I've had props come with sleeves it them to size them to my request. They were not soldered very well. These props do have a forward direction. I can't really type its description but could tell you over the phone when you get that far. When soldering them on its not easy your first time. The brass rod and bronze prop heat differently lots of care is needed.
  2. PrepmasterNick
    PrepmasterNick Active Member
    Lake Charles, LA
    Awesome! I was curious. What do the different numbers mean on there? 1515... 1620.... Prop angle?
  3. absolutek
    the first two digits are the size in inches, and the second two digits are the pitch measured in inches traveled forward in one complete revolution of the prop (in theory). So 1.5" diameter/1.5" pitch, 1.6" diameter/2.0" pitch.
  4. PrepmasterNick
    Lake Charles, LA
    ah. how do you know which one to choose or do you just use the ESC to fix all that?
  5. Bob
    Big BB & BC use 1.75"
    Small BB & BC & big CA use 1.5"
    Most med and small CA go 1.25"
    The really big BB use 2" & 2.25"
    If it's a single prop ship move up a size.
    PrepmasterNick likes this.
  6. PrepmasterNick
    Lake Charles, LA
    Ah, thank you
  7. irnuke
    New Bitmap Image.png This is my Baden.... 2.25" prop. :)
    'Oh my gahd, Jeffy, LOOK at that stern. It's so big and round...'
    'Yeah, it must be one of those rapper guy's boats or something...'
    I like big boats and I cannot lie...
    NickMyers and absolutek like this.
  9. Beaver
    I have a 1.75" prop on my cruiser. :)
  10. dmiowac134
    dmiowac134 Active Member
    Readlyn, Iowa
    Ok thanks Bob, I'll order them this week. Should I wait to cut out the shafts holes until I get the rudder done and props?
  11. irnuke
    dm, I suggest you read over some of the other build threads that show some of the (many) ways to do this. Most will have you figure out where the rudder post(s) will be, then align the propshafts so that the prop is directly in line with the rudder(s) (if 1 prop-1 rudder or 2/2) or tapering together toward if 2/1. Best setup (as shown on my Baden pic) is 1/2 where the propwash is directed between two rudders.
  12. Bob
    Use some 1.5" disks as props until they show up and get cutting.
  13. dmiowac134
    Readlyn, Iowa
    Here is the placement of rudder and prop shafts. 2015-01-24_15-49-12_362.jpg
  14. dmiowac134
    Readlyn, Iowa
    A side view. I'm not sure about the shape but its 1"tall by 3" long. 2015-01-24_15-56-34_158.jpg
  15. NickMyers
    Id take some length off that rudder and make it deeper.
  16. dmiowac134
    Readlyn, Iowa
  17. dmiowac134
    Readlyn, Iowa
    Ok NickMyers, I can see from the stern view that's I good idea. Will redo a new one and post when I've got it.
  18. dmiowac134
    Readlyn, Iowa
    Here is the redone design, might be alittle too tall??
  19. dmiowac134
    Readlyn, Iowa
    That's it for today boss says its time to go, will work on it tomorrow.
  20. Bob
    The shape looks right. But you might need to move it closer to the props now that the shape changed.
