U.S.S. Des Moines
Discussion in 'Warship Builds' started by dmiowac134, Nov 22, 2014.
  1. dmiowac134
    dmiowac134 Active Member
    Readlyn, Iowa
    Yep did some tinkering with the prop shafts. Also cut out rudder pieces from 1/8 ABS. 2015-01-30_03-02-39_580.jpg
  2. dmiowac134
    Readlyn, Iowa
    Both prop shafts cut, how far(length) should I cut? I know from other threads that you want to try to get them as level as possible. 2015-01-31_16-53-50_325.jpg 2015-01-31_16-54-33_155.jpg 2015-01-31_16-55-42_316.jpg
  3. John Bruder
    John Bruder Member
    Colorado Springs, Colorado
    Cut them far enough to get the shafts as level as possible as you said. They look long enough to me. You need to stick them in the gear boxes and then check prop position to see if you cut enough.
  4. dmiowac134
    Readlyn, Iowa
    Ok I'll do that tomorrow, thanks
  5. NickMyers
    I'm not sure what is going on with your post there. The admin side tells me you attached a file, but its not associated with the post
  6. dmiowac134
    Readlyn, Iowa
    Yeah not sure, I think its my phone. So I'll try to repost. This is what I've done on the rudder.
    Lou likes this.
  7. Bob
    The drive shaft on mine is 12" long. The stuffing tubes are a little shorter, enought for the prop and gear on each end. I try to make all ships with 12" shafts, then if needed I can swap prop shafts. Since the props are soldered on.
  8. irnuke
    A prop & gear on EACH END? Prop AND gear? So...does the motor connect in the middle & you have push-me/pull-you drive? o_O:p:laugh:
  9. PrepmasterNick
    PrepmasterNick Active Member
    Lake Charles, LA
    Would he still be able to swap shafts with that kind of drive?
  10. dmiowac134
    Readlyn, Iowa
    I just measured the shafts with the props and they are 10 1/2" long. Will start to look at the gear boxes.
  11. John Bruder
    John Bruder Member
    I have a question, Is the allowable rudder area given in the rules greater than the BC Des Moines rudder? BC would have to tell me its size.
  12. dmiowac134
    Readlyn, Iowa
    Jrbruder I'm not sure about that, someone with alot more knowledge will let us know. Here is a picture of the prop shafts inside the gear boxes. I have some shaping to the bottom of the gear boxes too get the shafts level. 2015-02-02_12-26-00_396.jpg 2015-02-02_12-26-28_579.jpg
  13. absolutek
    Make sure you put your motors on the gearboxes before mounting them permanently otherwise you may have them too close together.
  14. John Bruder
    John Bruder Member
    Everything is looking good so far. To help show how I did it, which looks much like yours I thought that I would save a 1000 words. This set up was copiedfrom several others ships. Hope this helps.
  15. dmiowac134
    Readlyn, Iowa
    Thanks jrbruder, I'll be looking at those throughout my build. Here's the gearboxes with motors installed after grinding down the boxes. Will check the shafts this morning to see if it helped level them. 2015-02-05_02-50-36_877.jpg 2015-02-05_02-50-45_207.jpg
  16. John Bruder
    John Bruder Member
    Yep, that looks like what I did to get them to set level before I epoxied them in. Keep up the good work. I think I have a couple more photos I can thow on here in case they might help.
    If you want, I can add some photos of two really nice DMs. One from Rick King and the other from Dana Graham. They are so nice I would hide my ship if they had theirs on the water.
    r/John
  17. John Bruder
    John Bruder Member
    Here are some pictures of the nice DMs I mentioned and my guns.
  18. dmiowac134
    Readlyn, Iowa
    WOW!!! Those ships are AWESOME! I've got a long way to go. I hooked up the gear boxes to the prop shafts and I need to do some more grinding. Will post pic today. Right now working on the drag disc's.
  19. John Bruder
    John Bruder Member
    They do have very nice ships. Mine is more a combat model with ABS super structure and definitely NOT pretty.
    Keep up the good work. Hope these motivate you to keep on going.
    r/John
  20. Lou
    Sounds like some girls I used to date
    Cannonman and PrepmasterNick like this.
