U.S.S. Des Moines
Discussion in 'Warship Builds' started by dmiowac134, Nov 22, 2014.
  1. Cannonman
    Hermitage, Tn
    Te He.... Me too...... More the combat model......:eek: :bang: :crying: :oops:
  2. John Bruder
    John Bruder Member
    Colorado Springs, Colorado
    I don't believe that for a minute. Lou, you look marvelous, el guapo.
  3. dmiowac134
    dmiowac134 Active Member
    Readlyn, Iowa
    Some more work on the gearboxes. 2015-02-08_18-05-16_258.jpg 2015-02-08_18-05-40_132.jpg
    absolutek likes this.
  4. dmiowac134
    Readlyn, Iowa
    Drag discs cut out of machinable 1/8 abs. 2015-02-06_01-39-04_718.jpg 2015-02-06_03-00-18_925.jpg
  5. dmiowac134
    Readlyn, Iowa
    Also did alittle widening for the stuffing tubes,so I can get them spaced apart better.
  6. dmiowac134
    Readlyn, Iowa
    Rudder is epoxied together, just need to shape it, will do this after work. 2015-02-13_01-28-25_950.jpg
    I was going to do boat work after work-work, but the cold front came though, and I ran inside to hide. Boat's looking good!
  8. dmiowac134
    Readlyn, Iowa
    Thanks tugboat, I has able to epoxy the rudder at work. Too cold yesterday, so I'll have to wait to glass the shafts when it warms up.
  9. dmiowac134
    Readlyn, Iowa
    Did some sanding on the rudder
  10. dmiowac134
    Readlyn, Iowa
    Placed rudder inside of hull and saw that the post was alittle off center, leaning toward the bow.
    so alittle sanding is needed. Hard to see in this picture. When it warms up some I'll get better pic.
  11. dmiowac134
    Readlyn, Iowa
    Also looked at rudder post and saw I need to sand it alittle too.
  12. Bob
    You don't really need to make the bottom match perfectly. I use CA glue to keep it in place the push some epoxy puddy or some other glue type thing into the space.
  13. dmiowac134
    Readlyn, Iowa
    Ok Bob, I've epoxied the rudder stuffing tube into place, but is out too high? Should it come thro the bottom of the hull alittle? 2015-02-19_15-37-36_255.jpg 2015-02-19_15-37-43_317.jpg
  14. Lou
    looks good. Just watch the height so the deck fits (and the rudder gear or servo horn fits as well.
  15. dmiowac134
    Readlyn, Iowa
    That's what I was thinking, if its too tall I will need to cut it down some. Once it dyes I'll check then install the post.
  16. Bob
    Looking at the gear boxes again, make sure there is room for the big gear to fit on the shaft. It looks like you sanded into the open space where the gears go. That's too far. Worse case is you use a smalled big gear. Not too bad for a cruiser as you are allowed to go pretty fast.
    Tugboat likes this.
  17. dmiowac134
    Readlyn, Iowa
    Ok, I didn't think of that. I'll check that out tomorrow too.
  18. Tugboat
    And if you're waaay too fast with small driven gears, you can always wire the drive motors in series, gives them half the voltage each.
  19. thegeek
    or the one with the lower internal resistance spins faster for no reason. Only parallel.
  20. Tugboat
    It will spin a bit faster unless they're waaay off, because in series, they run the same current. In parallel, the one with the lower internal resistance draw more current, which reduces torque in the other motor.
