U.S.S. Des Moines
Discussion in 'Warship Builds' started by dmiowac134, Nov 22, 2014.
  1. dmiowac134
    dmiowac134 Active Member
    Readlyn, Iowa
    CURT likes this.
  2. Bob
    Put at least 1.5" of glass and epoxy on the end and hull. These tend to break off a lot.
  3. dmiowac134
    Readlyn, Iowa
    2015-05-07_20-06-36_862.jpg 2015-05-07_20-06-44_495.jpg 2015-05-07_20-06-49_278.jpg 2015-05-07_20-07-04_612.jpg 2015-05-07_20-07-14_167.jpg 2015-05-09_16-34-40_830.jpg Got alittle more work done on the Des Moines. I was able to get an extra set of plans and cut out the top view and lay it on the deck. I'm going to use to place all the turret locations. Then double check to make sure they are right. I also cut down the rudder sleeve and post. I placed the smaller gear on the rudder shaft to see if I had ok clearance. I think its ok. Then I clamped the sub-deck to the hull to see if it was clear. It is, but not by much. The last picture is the sub-deck clamped and I measured to roughly the middle of the ship to see if its beam width was right?
    I do have a question; I cut down the plug by 3/8 and that has made the bow area hard to fit. Is there a safe way to flare the bow out?
    Tugboat and CURT like this.
  4. dmiowac134
    Readlyn, Iowa
    Thanks Bob H. got that done on Friday, now working on the rudder box. Making it out of 1/8 ABS. Got bottom and two sides on, just need to finish it.
  5. dmiowac134
    Readlyn, Iowa
    2015-08-03_15-29-23_716.jpg 2015-08-03_15-29-32_323.jpg 2015-08-03_15-29-39_507.jpg got subdeck sanded and fit into hull. Got Starboard side of subdeck expoxied on with clamps!
  6. dmiowac134
    Readlyn, Iowa
    2015-08-03_16-28-59_587.jpg Got rudder box done, but think its too tall to put into ship. Might have to get a micro server and build a smaller box. Will test fit after subdeck is epoxied on.
  7. Beaver
  8. dmiowac134
    Readlyn, Iowa
    Awesome thread thanks Beaver, I'll do that as soon as I hwy to the store.
  9. Beaver
    Thank Tugboat, he's the one that made the thread. ;)
  10. dmiowac134
    Readlyn, Iowa
    Ok, thanks Tugboat!!!!!
  11. dmiowac134
    Readlyn, Iowa
    Got Port side epoxied in place and also got hole drilled in side of servo. 1866.jpg 1865.jpg 1864.jpg 1874.jpg
  12. dmiowac134
    Readlyn, Iowa
    Got bracket for rudder servo placed and epixie in. 20150907_144111.jpg 20150907_144125.jpg
  13. dmiowac134
    Readlyn, Iowa
    Also got layout of internal in. 20150907_143203.jpg 20150907_143157.jpg 20150907_143151.jpg
  14. dmiowac134
    Readlyn, Iowa
    Not sure about the pump, looks a little tall. 20150907_143230.jpg 20150907_143225.jpg
  15. Beaver
    You pump looks like it should fit. If not, just cut a hole in your deck and hide it in the superstructure. Or find a shorter motor.
    EDIT: You might want to make sure you didn't put your motors where you guns will have to sit. One of the first things you should do on a boat is mark the turret locations so you don't put anything where the guns will have to sit. Otherwise you'll have to move the offending object and it is generally easier to move stuff around when it isn't glued to the boat. :)
    WillCover likes this.
  16. dmiowac134
    Readlyn, Iowa
    Well Beaver you were right, I checked and double checked and I've got the motor mounted where the guns will be. Thought I measured that right before I mounted the motors, guess I'll need to get longer prop shafts and move the motor mounts. 20150908_185010.jpg 20150908_184925.jpg
  17. dmiowac134
    Readlyn, Iowa
    I was wondering if these accumulators would work for my USS Des Moines. "Weapons/pneumatics" " Making of small accumulators:101? Its on page 3.
  18. dmiowac134
    Readlyn, Iowa
    Got a couple of goodies in the mail from BC. Got one more ordered! 20151015_215847.jpg
  19. dmiowac134
    Readlyn, Iowa
    Got accumulation tanks cut to size. Just need to drill holes and solder together. 20151102_103728.jpg
  20. dmiowac134
    Readlyn, Iowa
    Also got some construction paper and traced the stern decking out, just need to cut it and sand down alittle, then epoxy in place. 20151102_103758.jpg 20151102_103758.jpg 20151102_103739.jpg
