U.S.S. Des Moines
Discussion in 'Warship Builds' started by dmiowac134, Nov 22, 2014.
  1. Beaver
    Looking good!
  2. Bob
    Have you checked the tanks size with the solenoids connected to make sure they fit? They look pretty big, but looks in a photo might be off.
  3. dmiowac134
    dmiowac134 Active Member
    Readlyn, Iowa
    Thanks Beaver, its going slow but will devote more time to get it done especially since Winter is coming. No Bob I haven't yet, still trying to figure out what parts I need for the connection to tanks to solenoids. I ordered 1/4" to 1/4" male connector and 3 check valves from BC, but I'm having trouble trying to figure out the rest. I've checked other builds but haven't found exactly what I need.
  4. Bob
    You need:
    1 1/8" barb
    3 check valves, male one side, female other side
    4 90 deg fittings
    3 swivel fittings
    6 mail to mail fittings
    You might need something else depending on the air flow direction of the check valves. I'm not sure if the IN is male or female.
  5. thegeek
    In male out female
  6. dmiowac134
    Readlyn, Iowa
    Thanks Bob and thegeek, got parts ordered from BC.
  7. Bob
    Add 3 female/female couplings to your order.
  8. dmiowac134
    Readlyn, Iowa
    Thanks Bob, ordered placed!!!!
  9. dmiowac134
    Readlyn, Iowa
    20151103_165907.jpg 20151103_171740.jpg 20151103_171745.jpg Stern decking cut and shaped. More sanding for the rest.
  10. dmiowac134
    Readlyn, Iowa
    Finally had time to work on ship, got deck sanded down to fit on subdeck also got cut outs traced.
  11. dmiowac134
    Readlyn, Iowa
    Got cut outs cut, but looks like I cut the deck a little thin in spots. Darn jig saw.
  12. dmiowac134
    Readlyn, Iowa
    Got hole cut out for guns, now just need to trim up tube and figure out a way to mount, align guns.
  13. Packboy14
    Packboy14 New Member
    Long Beach, CA
    Hey its my favorite ship. Its looking great. Keep up the good work.
  14. dmiowac134
    Readlyn, Iowa
    Thanks Packboy14, Good news: got to work on U.S.S. Des Moines today, bad new's; guns are right above drive motors. So will need to move motors back. 20160815_145041.jpg
  15. dmiowac134
    Readlyn, Iowa
    Also gun magazines have a downward bend on them (not complaining) so they are hitting the bottom of hull, will need to bend them up some. 20160815_145047.jpg
  16. dmiowac134
    Readlyn, Iowa
    Got feed tubed on gun's bent so I can begin to figure out how to mount guns. How do I make sure the barrel's are at the right height?
  17. dmiowac134
    Readlyn, Iowa
    Got the guns where I think they are ok. 20160820_152421.jpg 20160820_152315.jpg
  18. jstod
    Looking good! I don't know if you solved the motor issue but one way I have seen issues like yours solved by mounting the motors facing forward on top or to the side of the shaft using a gear to turn the shaft.
  19. dmiowac134
    Readlyn, Iowa
    Thanks jstod, I just want back in my early post and saw that Bob H said that he users 12" shafts, so went to local hardware store and bought 12" 1/8" stainless steel rod.
  20. dmiowac134
    Readlyn, Iowa
    Got guns anchored down. Looks bad but will come back later and redo. 20160822_144532.jpg
