UPDATE ON MOGADOR!!!!!!!!! ( yes already!!)
Discussion in 'North Atlantic Battle Squadron' started by JRodgers, Nov 26, 2007.
Thread Status:
Not open for further replies.
  1. JRodgers
    JRodgers Member
    or would one of those be good enough for my boat?
  2. JRodgers
    JRodgers Member
    Chris,
    Hmmm.. do you think Chuck does all the work on the Mog??? I see you have "Good stuff Chuck"... ever consider that us females can do just as much.... Hmmm?? Waiting..... And if you think otherwise.. im sure your better half will help you along with that!
  3. bb26
    Joy. How many engines in the Mog. You do want to have 1 esc per engine.
  4. JRodgers
    JRodgers Member
    then i guess I only need one.... only 1 engine in the Mog.
  5. JRodgers
    JRodgers Member
    oops make that two maybe?
  6. bb26
    If it is running two engines then you need 2 esc's. In think Maritime hobbies have them. If I remember correctly the ESc that craig had was a proboat
  7. ProfessorChaos
    ProfessorChaos Active Member
    Centerton, AR
    Why do you need one ESC per motor?
  8. JRodgers
    JRodgers Member
    well then Yamatoman, speak up.. do i need 2 or not?
  9. bb26
    Joy. Craig had the NC running on 1 ESC and the speed could not be controlled. A single esc will have to handle the load for both motors. You can use 1 but make sure it is wired correctly. There is a thread under propulsion dealing with esc's
  10. Kotori87
    I can't think of any overriding reason to have 2 ESCs, unless the current draw of two motors exceeds the ESC's current rating. If the motors draw more amps than the ESC is rated for, the ESC will overheat and violently self-destruct. Stall current is the highest amount of amps that a given motor can draw, so if the ESC is rated for a higher amperage than the motors draw at stall, you're fine.
    For example, my Spahkreuzer is powered by three cheap surplus 365-size Mabuchi motors. They draw 2 amps each at stall, for a total of 6 amps stall current. My ESC is rated for 20 amps, so I can run all three motors with one ESC. Some of the larger ships use 500-size motors, which can draw significantly more current. Some can draw 80 amps or more at stall. If I were to use my 20-amp ESC with one of those motors, and then I got mossed or mined, my ESC would overheat and violently self-destruct, possibly damaging other parts of the ship. I have heard that a bunch of people used cheap, low-current ESCs with their monster power-hog battleships at NATs several years ago, and the multitude of failures due to mis-use gave ESCs a bad reputation. That's probably the origin of this "one ESC per motor" thing. If you just follow directions and use a properly rated ESC, then you will be fine with 1 ESC.
  11. Chris Easterbrook
    Joy there was no offence meant, I saw that Chuck had posted and just replyed.
  12. Jay Jennings
    A question wrt the rudder gears. How much swing does the gearing provide? 25, 30 45 degrees?
  13. JRodgers
    JRodgers Member
    it gives a 90 degree swing
  14. Chris Easterbrook
    wow that is a big swing Joy.
  15. ChuckR
    ChuckR Active Member
    It will ned to have some stops installed so she will not cause a roll over.
  16. Jay Jennings
    Wow is right!! Thanks for the info guys!
  17. JRodgers
    JRodgers Member
    Had Moggy on the water.. oh yes I did..... and can she move!!! WOW... she took off with the bow in the air!
    Shes got her hot pink coat on it and just wait till you all see the super structure.....its like WOW!!! I didnt have the camera with me while on the water, but I am hoping to have her back on the water this weekend maybe? and if so i will definitly have pics to go with it!!!
    Shes sweet!!
    And her name is : Miss Mog!!
    (thats even gonna be on the side of it with black hearts! HAHA!)[:X][:D]
  18. djranier
    So it sounds like the radio gear is working great for you.
  19. bb26
    It is good to hear Joy that the mog is on the water.
  20. Chris Easterbrook
    Wow good to hear that she did not have any gliches
Thread Status:
