Help! A Wild Bug! Uploading a resource gave me a security error...
Discussion in 'Website Issues' started by Xanthar, Mar 25, 2017.
  1. Xanthar
    Xanthar Well-Known Member
    Upstate NY
    I was trying to share the stl file for my 3DP Cage mast when I got the error mentioned above. Maybe 12MB is too big?
  2. NickMyers
    12mb should be no problem. Can you be more specific about the error?
  3. Beaver
    Did you try putting the STL into a zip folder?
  4. Xanthar
    Upstate NY
    When I select my file. The progress bar fills up and when it gets to the end I get this pop-up window. (See screen shot)
  5. Xanthar
    Upstate NY
    Working on that now. I also discovered that the site doesn't like unix style *.tgz archives : P
  6. NickMyers
    Stls are an allowed filetype and the upload limit should be much larger than 12mb, so that shouldnt be a problem :/
  7. NickMyers
    If memory serves... That usually means your session went stale
  8. Xanthar
    Upstate NY
    It liked the Zip file. I've never used Mint's compression app to make a zip before, though. Can anyone open it?
  9. Beaver
    Yeah, I can open it up. I get an error that it isn't manifold though.
  10. Xanthar
    Upstate NY
    OK that's odd.
    I just unpacked it in a different folder and checked it with meshlab and slic3r. Both say it's a valid manifold.
    What tool did you use?
  11. Beaver
    It was Repitier Host that was saying it wasn't manifold. Slic3r didn't have a problem slicing it.
