Using arduino relay for pump switch
Discussion in 'Electrical & Radio' started by warspite, Jul 25, 2022.
Tags:
  1. warspite
    warspite Active Member
    ☘️ The Irish Sea ☘️
    Hi,
    Has anyone had success using arduino relays with RXs? I am looking for an alternative pump switch for my cruiser and came across this guy. The coil triggers off 5v, and it can switch 10a at 12v, which should be plenty for a cruiser. Do you think this would work? It is 2.50€ (About 3 dollars)). Would the signal from a RX running from a 4.8v battery be enough to trigger it?
  2. darkapollo
    darkapollo Well-Known Member
    Carlisle PA
  3. Panzer
    Hell, MI
    I would get one and try to see if you can get it to work///// Pololu has this variation
    Pololu RC Switch with Relay (Assembled)
  4. warspite
    ☘️ The Irish Sea ☘️
    Does Pololu also have a switch suitable for firing guns? I saw these switches before but not sure I could get them as I live overseas…
  5. Beaver
    https://www.pololu.com/product/2803
    I use these on all my guns.
  6. warspite
    ☘️ The Irish Sea ☘️
    Thanks!
    I found a distributor in Spain, I will order a couple of the firing boards and the switches and give them a whirl.
    Cheers!
    Panzer likes this.
