USS Baltimore
Discussion in 'Warship Builds' started by Wolcott27645, Dec 24, 2014.
  1. rcengr
    I've tried it. It doesn't work. At flank speed they make some additional drag. But at turning speeds, they are sometimes more effective then the main props, which may cavitate at full throttle and low speed. The net result being slower acceleration when starting from a dead stop and slightly worse turning.
    Also, it's extra complexity. Extra complexity bad. No one believes this until after they build and battle.
  3. NickMyers
    I cannot +1 this enough
    Kotori87 and PrepmasterNick like this.
    I meant to include myself in that group. I didn't believe it until I battled. So please benefit from our collective rookie mistake :)
  5. NickMyers
    Likewise. I still suffer from 'lets make it more complex!' but my lack of time lately has stopped it from being a major issue...
  6. warspiteIRC
    warspiteIRC RIP
    Annapolis, MD
    I suppose they could free spin, just no power.
  7. Radioman
    Radioman Active Member
    Franklin Wisconsin
    I ordered a kit the other day. Waiting for it's arrival.
  8. Radioman
    Franklin Wisconsin
    Received my kit today. The laser cut wood is great. Can't wait to start in on it.:)
  9. Cannonman
    Hermitage, Tn
    Post some pics, and make sure to ask questions if you are unsure of something, preferably before doing the wrong thing ;)
  10. Radioman
    Franklin Wisconsin
    I will do that. Right now I am cutting out the frames.
  11. Radioman
    Franklin Wisconsin
    I have all the parts cut out and ready to do dry fitting. Place an order today for pops and pump so when neaded I will have it.
  12. Radioman
    Franklin Wisconsin
    I am fitting the frames and keel and sub deck. Question should the bottom of the keel be flush with the bottom of the ribs? Parts are very tight fitting so some sanding is required for a snug fight.
  13. NickMyers
  14. Radioman
    Franklin Wisconsin
    Thanks Nick. I thought they did. Some more sanding and fitting to do.
  15. rcengr
    If they are a little tight I generally use a scrap piece of wood to pound them together or use channel lock pliers to squeeze them together. Because of the curvature of the hull, the keel will be a little below the bottom of the ribs, particularly at the stern. So don't make the notches any deeper or the deck will not be straight.
  16. Radioman
    Franklin Wisconsin
    I have been giving them a slight nudge with a small mallet. So far going good
  17. Radioman
    Franklin Wisconsin
    I am ready to skin the hull bottom on mine. Has a twist in the hull but worked it out.
  18. Radioman
    Franklin Wisconsin
    I did not build this ship for battling since I have no one to battle with. Here are some pictures of the build.
  19. Radioman
    Franklin Wisconsin
    Starting to look like a ship. P1020545.JPG P1020546.JPG P1020547.JPG P1020548.JPG P1020549.JPG
    Nick Park, froggyfrenchman and rcengr like this.
  20. irnuke
    Will be a good looking ship on the water. Good job!
