USS Florida (B) and SMS Viribus Unitis Builds!
Discussion in 'Warship Builds' started by NWCafesurfer, Oct 2, 2019.
  1. NWCafesurfer
    NWCafesurfer Member
    Washington
    Many thanks, ordered some silversolder supplies. Well give it a shot ;)
  2. NWCafesurfer
    NWCafesurfer Member
    Washington
    Happy thanksgiving everyone from our shipyard to yours!
    We're steadily working towards stuffing tube day! Measure twice cut once and all that that stuff.
    Passed afew milestones with the mounts and gearbox, things are lining up nicely. Still need to bench test the setup, but I'm feeling confident enough to post the files if anyone would like.
    550 Drive Motor w/ 10-tooth 32DP Pinion Gear
    View: https://www.amazon.com/dp/B075WZ21JW?psc=1&ref=ppx_yo2_dt_b_product_details
    Traxx 28-tooth 32DP
    https://traxxas.com/products/parts/1526
    This setup gets about a 3:1 reduction ratio ;)
    Additional details to come, Happy Holidays!
    darkapollo and Litch42f like this.
  3. Litch42f
    Litch42f Well-Known Member
    Nevada
    Slick looking gear box, keep up the good work! Something that sticks out to me, and those with more experience please chime in, but I think 40000RPM motors may be a little too fast/low torque for drive motors, even with a 3:1 reduction. I could be totally off base but my 15lb, 26 sec I-boat which has I think 15k RPM 550 motors on 7.4v and an about 3:1 reduction still has a significant ESC reduction to make speed. So you might have trouble keeping the speed down and/or have poor acceleration? Or I could be totally wrong and you’ll be fine. Anyways, something to look out for and keep posting updates!
  4. darkapollo
    darkapollo Well-Known Member
    Carlisle PA
    At 2.8:1 you’re looking at over 14k at the props.
    I’m sure you’ll get that sorted when it is time to speed test. Swapping motors isnt hard.
  5. Kevin P.
    A couple suggestions for the gearbox
    • It looks like the shaft is being supported by thin ABS as a bearing surface, which I don't expect to last under load. It's better to run the stuffing tube into the gearbox and to rely on the stuffing tube bearings/bushings (typically Oillite bushings) to be the contact surface with the shaft. Having the gearbox be in contact with the stuffing tube spreads the normal force from the gears over a larger area. Take a look at the Traxxas Villain gearbox design, several guys have draw up printable files and posted them on here
    • It's not clear how the motor is attached to the gearbox, looks like maybe friction tape? Friction-based mounts can work in certain applications, I try to avoid them for a gearbox design since getting proper gear engagement is very important. Typically gearboxes will use the bolt holes on the front of the motor can with slots in a plate to allow setting proper engagement between the gear. Motor replacement can still be fast with the bolt-hole mounting, just ensure there is space to get access to them (don't put a cross member in the way)
  6. darkapollo
    Carlisle PA
    Good call @Kevin P.
    That shaft is going to chew through that mount in seconds. You really need shaft bearings to support it.
    What are you using for stuffing tubes?
  7. NWCafesurfer
    NWCafesurfer Member
    Washington
    I completely didn't know/ realize there's different rpm models?? I thought a 550 was good as any 550... :(
    Those are going back, lol
    Being a slow 38 second boat, what rpm 550's should I be looing for?
    These are the stuffing tubes I'm going to use, they accept a 4mm shaft & I modified them with zerk fittings (for ease of maintenance)
    All the forces 'should' be acting on these and into the hull.
    As others pointed out the thin ABS bearing surfaces, these are 'templates' a replaceable part of my gear box that allows me to dial in my gear spacing/engagement with out having to reprinting the whole motor mount assy.
    Looks like I'll need new motors (of the proper rpm). Possibly new pinion gears and remake my templates to get the gear spacing right.
    Bummers, was so looking forward to cutting the holes for the tubes :rolleyes:
  8. NWCafesurfer
    NWCafesurfer Member
    Washington
    *with regards to the 'templates' once they're perfect I'll print a thicker 3mm part that gets epoxied in.
  9. darkapollo
    Carlisle PA
    *28 second boat for the VU.
    Austria-Hungary Viribus Unitis DN
    • LOA (in)
      41.58
    • Beam (in)
      7.5
    • Max. Wgt.
      18.15
    • Ship Class
      4
    • Units
      4
    • Speed
      28
    • Shafts
      4
    • Rudders
      2T
    It is much easier to get a 10k 550 and gear down from there. Ideally you want 3-4k at the prop and then ESC trim to get it in speed. BattlersConnection has some 550’s that will work. I don’t have the Johnson Motors part number off hand.
    On my Derf, a 24s boat, I am running dual 10k 550’s 3:1 42p gears 11/33 and the throttle is trimmed to 41% with a 1.5” prop.
  10. Beaver
    NWCafesurfer and darkapollo like this.
  11. NWCafesurfer
    NWCafesurfer Member
    Washington
    Many thanks! The comparisons are very helpful, I'll do alittle research on that, but 10k 550's sounds like a good place to be. I have a pile of Hobbywing 1060 60A ESC's that should be overkill for a low rpm/ high torque 550..
  12. darkapollo
    Carlisle PA
    I’m using the 1060 on my Derf. It does well
    NWCafesurfer likes this.
  13. NWCafesurfer
    NWCafesurfer Member
    Washington
    They just arrived, Twas too good to be true..
    I'm certain they'll make good bilge pump motors! LOL
    Played it safe this time, ordered my 550's from Battler Connection
    You bring up some very good points! Think I'll go with McFadden's Traxxas Villain gearbox to get it on the water. My friction mount can be a side project, don't want it to delay construction ;)
    Many thanks to everyone for the words of wisdom, I'll get there =)
  14. Beaver
    That's not the right motor, dude.
    darkapollo likes this.
