USS Gearing
Discussion in 'Warship Builds' started by Lou, Apr 24, 2017.
  1. Lou
    Will hijack my own thread. When ordering from Sig, I am not seeing a secure connection when going through the checkout process, is this the same for anyone else? I created an account, but when I get to the payment screen and it asks for what CC # it is not secure (same for anyone else)?
  2. pigeonfarmboy
    Champaign, IL
    Not secure for me as well.
  3. Lou
    Whoops, I will update this today.
  4. Lou
    This is the magazine tube near the cap. In the picture you can just make out the second tube that is used for reducing the diameter so there is not as much flow. The issue was double fire (seems the flow was really pushing a second BB into the breech). Now, no more doubles...
  5. Lou
    Ladies and Gentlemen, I give you the "Avenger" cannon
  6. NickMyers
    so what was questionable about this? Earlier I thought you had implied a potential rules issue? I don't see one..
  7. Lou
    No, I didn't want anyone thinking it was not safe as it is not the standard design. Rules comment turned out to be unfounded as it went very smoothly. To the few that I showed the cannon they didn't see any safety issue. Just error on the side of caution
    rcaircraftnut, Panzer and NickMyers like this.
  8. Lou
    Business end, duals!
  9. Lou
    They are mounted in the superstructure.
    Just swivel to access the magazine caps or remove each cannon.
    rcaircraftnut and Panzer like this.
  10. Lou
    Superstructure removed from hull, would do this to add BB's.
  11. Lou
    So what is so cool?
    The magnets (one on each side of the Tee) holds the BB in place. The pin has a point on the end, this helps to separate the BB's so that only one fires at a time. A groove is cut on the flat part of the Tee to allow a little more gas into the gun.
    No uptube means little wear (slamming into the top of the elbow), shorter distance for the BB to travel which means faster pulls on the trigger.
    Big plus is it can fit into most cruiser superstructures and have the barrels exit the turret face.
    Judge for yourself...
    Nate G, rcaircraftnut, Panzer and 3 others like this.
  12. SteveT44
    Nice work. Now add plastic mag and aluminum barrel and cut the weight by half!
    rcaircraftnut likes this.
  13. Beaver
    I'm thinking 3d print the Tee and cut the weight to a quarter!
  14. Lou
    I will weigh the gun, but it is light with the thin walled tubing. 3D print the bottom of the Tee and the magazine cap and that would be a good start.
    Looking at Strikes injection pin method would allow an even stronger magnet to be used.
    What is also great is each builder can make their own version, this is nothing new other than design.
    The gun can be fired pointing in any direction, so the Tee does not need to be in the down position. I have it that way on the Gearing to keep the top weight down. If this was the fletcher, I would have the Tee on its side. The only deck penetration is for the gas lines, so no need to worry about swamping the boat in reverse.
  15. vicious p
    vicious p Well-Known Member
    Greensboro NC
    Any more pics or videos of the gearing or Fletcher's in action? Finally pulled mine back off the shelf and started working on it again.
  16. Anvil_x
    any movement on the Gearing/Avenger cannons?
  17. Anvil_x
    Just got a good look at a pair of Vac-u-boat Fletchers in refit over at John's house today. those things are pretty fantastic little ships. I'm going to have to get ahold of them and see about getting a kit or two
  18. rcaircraftnut
    Oklahoma
    Are these availible yet? I am going back over the road and am looking forward to getting back on the water this year in a big way.
    vicious p likes this.
  19. Anvil_x
    Last I talked with Phil, he's fixing to make some Gearings soon. he said he'd get back to me about the price point once he has a batch made
  20. rcaircraftnut
    Oklahoma
    What regulator are you guys planning to use in these?
