USS Indianapolis (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Oct 18, 2020.
  1. Kevin P.
    Starting a new cruiser project. This one has been in the queue for a few years now. With the loss of Strike and the Northampton hull, I decided to make a mold to fill the gap since it's one of the best Allied cruisers. Hopefully the rule change to allow Class 3 to split one unit passes this year so it can get Triples. I'm also considering making printed internals to make a hybrid fiberglass / printed boat. The idea would be to make a plastic hull slightly smaller than scale, then insert it into the mold while laying up the hull before it cures. I wont be doing that yet, the first one will be traditional to get the layout straight, I also prefer to spend hobby time in the build area instead of behind the computer. I chose Indianapolis because of it's fame, also it's sister ship is the Portland, names after Portland, ME which is a city I visited often growing up.
    Traditional plug making. By now I know how to make more optimal cuts to save time. Here is tracing the keel, leaving area for the divider plate for when I make the first half of the mold, while on the other side leaving a template to bend the deck piece
    Most of the pieces fit on one 4x2 sheet
    Loose fit here, nothing fastened
    Will start by fastening the deck template, then the keel, followed by each frame.
    Will fill with foam, brought some 2" home from my parents house
  2. Kevin P.
    Resumed work this weekend, glued frames down and cut foam. Foam will still need notches for the balsa blocks, tape was for transport
    Using Steve’s new bandsaw was great, made the process much faster
    Nibbles1 and Beaver like this.
  3. Anvil_x
    I like the insert idea. Just spitballing here, but instead of printing, perhaps a vacu-forming?
    You can crank out a vacuum-forming mold in a manner very similar to making this plug and mass production would be far faster/cheaper with a vacu-formed hull insert
    You could accomplish the same desired effects. even do it in CAD and then have a CNC machine carve your vacu-form. Might even be able to get those vacu-boat guys to take a swing at it for mass-pro
    Either way, looks great so far. just thought I'd drop that good idea grenade in your koi pond.
  4. Commodore
    Commodore Well-Known Member
    Sunny TX
    Nifty, but why not just print the hull at that point. I think we've reached the point where it should be plenty doable.
  5. darkapollo
    darkapollo Well-Known Member
    Carlisle PA
    Looking good!
  6. Kevin P.
    Thanks for the idea, but no room in the apt for a vacuum forming rig - while the variable cost of a vacuum formed part would be less, the fixed cost for equipment is way more than what I already have - I recall Phil saying that he could do something like an Atlanta (maybe 48" limit).
    I'm not holding my breath for putting in the time to draw up the printed part anytime soon, too much computer time for work. The idea with the hybrid is to deal with tradeoff between impact resistance and weight for printed hull, while significantly reducing build time. might end up just being some keyboard pipe dream haha
  7. Anvil_x
    I still think it's a neat-o Idea. It's worth at least putting the ideas down on paper for posterity. You never know when those notes could be a game changer.
    I have been bouncing around with a slightly different concept but.... 18 active timber sales are keeping me busy.
  8. Kevin P.
    Foam cut and glued in with foam board construction adhesive - use ribs to trace then cut on band saw - way less sanding using this method with the thicker 2” foam. Maybe sand a bit tomorrow afternoon (this is without any sanding)
    Panzer and wfirebaugh like this.
  9. wfirebaugh
    wfirebaugh Well-Known Member
    El Paso Texas, USA
    I like your style, I was having near the same idea when I started my Nagato class BB.
  10. Kevin P.
    Got some sanding in
    notSoGnarly and darkapollo like this.
  11. Kevin P.
    Finished sanding and layer of spackle down
  12. Anvil_x
    Nice. it's gonna be cool to see this step-deck process.
    is that a Nagato I see under the Scharnhorst?
  13. Kevin P.
    Fuso, a build that keeps getting kicked down the road - maybe this year, will depend how the other builds go
    Anvil_x likes this.
  14. Kevin P.
    Sanded and painted. Hull shape is good, no major correction needed, just need to smooth out surface a bit. Going to try to not polish the cannon ball this time - funny thing about making the plug is the bottom of the boat stands out the most, but it’s the part that never gets seen. Next layer will be joint compound film.
    Beaver and Commodore like this.
  15. Commodore
    Sunny TX
    And just what shape is a Polish cannon ball???
  16. Scott Thompson
    Scott Thompson New Member
    New Hampshire
    Any updates on this build?
  17. Kevin P.
    Picking this back up, will mold with the sodak
  18. Kevin P.
    Mold part 1 done
    Boatmeister, NWCafesurfer and Nomercy like this.
  19. Kevin P.
    Mold part 2 formed and sanded, just a few spots to bondo then ready to prep for hulls
  20. Kevin P.
    After 2 years finally have a hull
    it’s a bit thin so I’ll go over the rib locations with a couple more layers, the boat lines are good though, should be a solid allied cruiser
    Boatmeister, Mark41 and Beaver like this.
