USS Indianapolis (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Oct 18, 2020.
  1. Kevin P.
    Float test done at various weights, probably aiming for around 10 lbs
  2. Commodore
    Commodore Well-Known Member
    Sunny TX
    Looks very nice!
    Kevin P. likes this.
  3. Kevin P.
    Ribs starting, need to add some glass so I decided to do a video on reinforcing before and after cutting out the hull
    The other side I’ll reinforce before cutting
    Boatmeister likes this.
  4. Kevin P.
    Ribs reinforced and hull cut, I ended up with battleship ribs
    Drivetrain next
    Boatmeister, Panzer and Beaver like this.
  5. Commodore
    Sunny TX
    Well, that should be pretty darn durable...
  6. Kevin P.
    Picking back up 3 years later. Planning to work on the fiberglass one soon now that I’ve crossed off most things from my other ships’ punch lists from this year. She can now get triple sterns with 2.5 guns, which is a plus from the delay
    also starting a print version. Overall I’m pleased with the hull shape
  7. Kevin P.
    Stuffing tubes in the weekend. 1.25” props
    Old brown filler my dad had lying around
    I’ve made more progress on print version, drivetrain is drawn up and main internal forms are done. will share screenshots tomorrow
  8. Kevin P.
    Updates on the print version. Coming along well so far
    Stern aspect
    Running gear
    Motor mount and rudder mount
    Bow internals, cutout for 3.5oz bottles
    Bow aspect
    Lou, Boatmeister and JustinScott like this.
  9. Kevin P.
    Drag shafts and motor mounts in
    they stick out a bit but should be ok on a cruiser
    Motor mounts plastic weld
  10. Kevin P.
    Rudder mount in. Using 2 idler gears based on hull height
    waterchannel boundaries
    Also working more on pump. Made the top plate and small strainer frame
  11. Kevin P.
    Waterchannel filled in
    Bow divider for internal armor since the bow is so narrow at the waterline. Drying with boat vertical
    Next up is deck
    Boatmeister and Lou like this.
  12. Kevin P.
    Ready to print the main hull (I hope!)
    Bottle holder
    Overall
    Running gear
    Hope it works out!
    Iunnrais likes this.
  13. Kevin P.
    Got the subdeck in
    Selling gaps from underneath
    also print started
    Lou and Beaver like this.
  14. Kevin P.
    Progress on both. Lots of deck epoxy jobs
    deck pieces
    now bilge keels
    fully printed hull
    Bottle fits
    Underside
    measurements
    bit narrow to allow for tape and balsa
    motors seem to fit
    Boatmeister and Beaver like this.
  15. Beaver
    Looking good, Kevin! Is the printed version so you can have His and Hers?
  16. Kevin P.
    Catching this one up.
    Some side by side of fiberglass vs printed. See other thread for printed details. I’ll leave this one focused on comparisons and fiberglass
    Weight comparison. Printed hull was 6oz heavier than fiberglass at an equivalent point, not too bad
    Made from same plans, generally came out to same shapes
    going to try to keep builds moving together. Put the pump mount in this weekend
    Need to check for mag clearance around pump motor and subdeck. More room on starboard
    I could make the 4 post holes work here
    Boatmeister and GregMcFadden like this.
