USS Missouri Build (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Nov 29, 2016.
  1. thegeek
    Hard to sink? Or scarred of getting too close? Or what?
  2. daisycutter
    daisycutter Active Member
    Even with it being dead in the water they were still frightened by the Imperial crest
    buttsakauf likes this.
  3. prnd21
    prnd21 Member
    Burlington, NJ
    Maybe I missed it, but what type of paint did you use on this ship? Color/brand/type/matte or flat?
  4. Kevin P.
    Believe topside was a grey primer (rustolium brand, spray) sides are latex after browsing through color palates. Not sure of historical accuracy of specific shades, I tend to focus on functionality over looks
  5. Kevin P.
    Started the second significant refit over the past week. Plan is to do the following
    • Improve acceleration - swap motors, maybe props
    • Change gun layout - stern sidemount and bow guns
    • swap pumps - 1 brushless auto, 1 brushed
    • clean up some internals
    Motor testing continued. Previously ran 750kV 42mm outrunners. I was not pleased with motor reversal time - time changing direction from full forward to full reverse. I had hoped to be able to get 750's in there but doesn't look like the motor plates would survive the mod. I ran a motor fight club, putting several models head to head.
    500kV vs 750kV (shown below) - 500kV won out
    500kV vs 1100kV 38mm - 500kV won out again. 1100 wasn't quite as bad as the 750kW
    500kV vs 550 brushed - Brushed motor won handily, which is what I expected
    Since I couldn't get the 750 onto the mounts (without preventing the mounts from being used with the 500kV), I will go with the 500kV for now. Also considering 24V 555 if the performance on the water doesn't pan out. I took videos of a few other the comparisons, might post in the future
    printed a pump shield. It snaps in on the bottom, has two supports on the back
    came out alright, probably will tweak the dimensions a little for the next one
    shifting gun layout
    This is before. keeping B turret, shifting A to 15 degree bow guns. Will have to shift bottle for clearance
    Stern guns. Pretty useless with the length of the stern deck. will be nice to have dual stern sides
    worked on wiring in the boat, removed about 10-15ft. Boat serves as bench
    printed up switch holders I made for another boat
    next steps will be new gun mounts, finishing the pump conversion
    rcaircraftnut, bsgkid117 and Beaver like this.
  6. bsgkid117
    Kevin, I'd love to see your motor comparison video. Would be nice to have a legit reference for some of this stuff instead of just speculation about the magic behind magnets and how they work.
    rcaircraftnut likes this.
  7. Kevin P.
  8. Kevin P.
    Worked on some gun mounts
    general idea
    At the bow
    should work sort of
    stern guns modified and mounted
    used existing mounts on underside
    Tomorrow will be bow guns, hard to clear the bottle, maybe some wiring and pump mounts
    Also have a plan for getting 775s mounted
  9. Kevin P.
    Next iteration of pump shield, with mount wings
    Mounts will be bolted to hull, pump slides in and out
    snap fit around BC pump
  10. Kevin P.
    Aft guns set, swapped switch holder
    bows tomorrow
  11. Kevin P.
    Bow mags before. Going to have them come through the deck for ease or reloading
    I thought about making motor adapter plates to get the 775s in. 3/16 aluminum. needed to buy a bit for bushing hole
    29mm and 25mm holes
    Motor attaches
    M3 holes tapped. looks like it will work
    showing tapped holes through motor
    Will probably have to make another initial one, but should work
    Needed to make new mags for the ship because they were modified and rebent a few too many times. Removing the connections
    continuing work on mag mods, motor plates
  12. Kevin P.
    Rev 3 of the pump shield. The winged version was too tight for the room I have on Missouri, I think it will work OK on other projects
    Rev 3 added holes to go on the existing posts from my brushed pump mount
    installed
    with outlet hose
    overall it looks like a solid setup. Pump lifts easy for between sortie gunk checks, but firmly in place for operations. Will need water testing, but I might use the post idea on future builds as well for adaptability.
  13. Lou
    Kevin, do you order your copper tubing for mags online?
  14. Kevin P.
    I get 1/4” copper tubing from Lowe’s/Home Depot in 10’ or 20’ lengths for a reasonable price. All of my other gun fittings I order online as Lowe’s/HD can charge 2-4x as much for lower quality products
    Lou likes this.
  15. Kevin P.
    Gun mounts
    Aft hatch
    one set of bow
    grip on mag for multi axis twists
    one in
    need to be deliberate with bend sequence
    Second one
    End result
  16. Kevin P.
    Last holder done. Should be hitting close to the water at bow.
    15 degrees marked on deck, but mounts will keep everything legal
    Printed mount for mags topside
    next step is an epoxy job to seal up each of the small mods here and there, then reassemble guns.
    I’m thinking about 24v 755 drive. Just ordered some spark escs (delayed based on temp shutdown). I’ll have to see on pumps if I want to go 555 24v or 4s 2300kv brushless, will need some side by side testing. Hopefully I’ll get the motor plates ready to go this weekend
  17. Kevin P.
    Finally got the epoxy job done
    Put the old dummy barrel from bow turret in stern turret
    Bow turret
  18. Kevin P.
    Got the guns in post epoxy
    Pump setup for now
    cut out SS for mag clearance
    need to wire up brushless pump, get the auto switch set up, reroute a few co2 hoses. Hopefully sea trials next weekend. Planning to test and video tape with 500kv and then shift to 24v 755s and repeat testing/video, should get solid comparison
  19. Kevin P.
    Turrets remounted, also potted Kessler switches
    Not the prettiest
    Bow came out better
    Getting there. Looks like sea trials will be on hold until the shelter in place is lifted
    Renodemona and Beaver like this.
  20. Renodemona
    Hey, just curious why you went with the sidemounts in B and the funny gun in A?
