USS Samuel B. Roberts (John C. Butler class DE)
Discussion in 'Warship Builds' started by Kevin P., Jan 25, 2017.
  1. Kevin P.
    Some more painting, went with measure 22 briefly
    Decided to shift to measure 32, blue was too dark
    Base of light gray
    This was waterline
    Waterline done
    Start of measure 22
    Measure 22, ended up being for not
    Scaled up camo and will use as templates
    3than, Beaver and bsgkid117 like this.
  2. Kevin P.
    Here is intended camo
  3. Kevin P.
    Work on painting
    Kinda of pain to tape, prep for black
    Port
    Three quick coats
    Need to sand before the last coat, then painting deck
    bsgkid117, Beaver and modelshipsahoy like this.
  4. Kevin P.
    Paint isn’t too bad. Will need a bit of TLC
    Will paint deck tomorrow, then SS over weekend
    thegeek and bsgkid117 like this.
  5. thegeek
    Beautiful job!
    The deck paint on the Slater is multi color m 32, like the sides.
  6. Kevin P.
    Thanks, I’m pleased with how it’s looking
    Went with the pattern from the guide
    Came out good. Will need to clean up along all edges
    Moving the superstructure next, probably balsa base
  7. modelshipsahoy
    modelshipsahoy Vendor
    Michigan
    John C Butler Molds getting closer to production
    31A3FF8E-F0A8-43A7-B520-E317397C2EC9.jpeg EAF4713C-358D-45C9-B32A-7AB03BBE3AE2.jpeg
  8. modelshipsahoy
    Michigan
    We probably could have just gone into production with this hull, after yesterday’s sandout, but I got a little picky. A couple spots and went through one more grind/fill/spray layer. It’s gonna be a nice little boat and super cheap!
    0CB3793B-6E0A-4AF7-80A1-CC0BA08EB5BB.jpeg 4605AF8D-7E64-40F2-9D57-F17E7F6503E9.jpeg
    Nate G and Beaver like this.
  9. Kevin P.
    Back to work on this
    Starting on superstructure
    Going to print the remainder, I think it will come out nicer. Getting started in fusion
  10. Kevin P.
    More work over the past few days. Drew up next part of SS
    More painting, cleaning up tape lines
    Took a few times to get her to print, but eventually came out OK, good enough to serve as base form
    I’ll keep working on drawing up the next parts, surface prep and painting of SS, a few more spots to touch up on hull
  11. Kevin P.
    More printing. Took a bit longer to draw everything up than I had hoped. Decided to print first deck too.
    Tan into an issue mid day with layer shifting, so I’ll need to check out the pulleys. One of the prints might be salvageable. Will need to reprint bridge
    Aft portion of first deck
    Bridge. Had to look at a lot of pictures to figure out the configuration
    Getting a feel for how it looks with super
    Paint touch up is about done on hull, only black remaining
    Once printer is back to 100% I’ll move to making the printed parts look non-printed, might do acetone or just paint/spackle. Will get those painted and smooth before gluing to hull and adding details
  12. Nate G
    Nate G Well-Known Member
    Bradford, PA
    Definitely want to acetone vapor bath to bond the layers the best and smooth them for appearance. ABS correct?
  13. Kevin P.
    I’ve been working through some printer pains, but finally moving forward. Acetone vapor worked great on a few pieces, not on the upper deck/bridge pieces that warped along the thin layer at the bottom. I think I have at least four bridges and a few mid level pieces done that I can save for the combat version. Can’t really tell but lower deck level is glued together, pretty smooth from acetone. Next two layers are untreated
    Painted with primer. I’ll shift to normal methods to get the outstanding portions smooth. Looks decent from about 10ft away
  14. Nibbles1
    Nibbles1 Well-Known Member
    Orinda, CA
    Wow. I actually wrote a report on the battle of Samar for the 7th grade nonfiction unit last year. Well done.
    Sammy
  15. modelshipsahoy
    Michigan
    John C. Butler molds are finally ready for production! Gel getting sprayed today!
    Nibbles1, Kevin P. and WillCover like this.
  16. Nibbles1
    Orinda, CA
    Ooooooh. I want one, when will it be for sale?
  17. modelshipsahoy
    Michigan
    3 sold already... will post up here when the backlog is knocked out.
  18. modelshipsahoy
    Michigan
    Finally done! MSA US Destroyer Escort hull #1
    On its way to @Nate G
    3F99580F-5760-459E-A85B-C75879FB6E1E.jpeg 04434F70-DF75-44A0-B0D0-FB95FF468759.jpeg E5190FEF-17A7-422E-BEAC-058BEDD03F83.jpeg 6BE9627C-5B15-4292-88D2-26E7E884561B.jpeg
    buttsakauf, Nate G, Nibbles1 and 2 others like this.
  19. Nate G
    Bradford, PA
    And it is lovely!!! thin gelcoat. not a single air bubble. smooth inner finish. thin layers FG as appropriate for this light weight a model. well done , sir!
    It will build into a nice ship.
    modelshipsahoy likes this.
  20. modelshipsahoy
    Michigan
    Thanks Nate!
    Enjoy!
