USS Shields 1/144
Discussion in 'Warship Builds' started by USS Shields, Jul 9, 2017.
  1. NickMyers
  2. USS Shields
    USS Shields Member
    Washington, DC
    Okay. Can I buy them from you then?
  3. SteveT44
    I can help you build your own (I have all the parts) or you can buy a Fletcher cannon from Battlers Connection for $35. The one I would help you build would be much lighter than the BC cannon. Besides the cannon you'll need a lightweight regulator and either a manual on/off CO2 valve or an electrically powered valve called a solenoid.
    http://battlersconnection.com/fletcher-50-round-cannon/
  4. USS Shields
    USS Shields Member
    Washington, DC
    If you guys have a meet-up in late august/september I will happily come and use your help. Some stuff is a bit too complicated for an eighth grader that does software and not hardware:)
