USS Washington build
  1. Gettysburg114th
    You are correct sir.
  2. donanton
    donanton Member
    I found a 6v36ah battery and a 6v20ah battery on batterymart. Is the 20ah good? The 36ah sounds like its a little much.
  3. SnipeHunter
    I would go with the 36ah battery, thats pretty standard for a NC. There isn't really an advantage to using a smaller battery since the ship has plenty of space and weight. Depending on your setup if you run a 20ah battery you might have to worry about running low on juice towards the end of the sortie which is when you need it most.
  4. donanton
    donanton Member
    At http://www.staabbattery.com/mm5/merchant.mvc?Screen=PROD&Store_Code=staab&Product_Code=UB6360-U&Category_Code=sla-06
    I found a 6v 36ah battery for 58.32 with shipping.
  5. Gettysburg114th
    I find that using the smaller batteries gives you one advantage. They can be used in a smaller boat.
  6. donanton
    donanton Member
    I'll order the battery from staab.
  7. djranier
    I got these guys to offer the 36 amp at $40 last year, and its still listed at that price. They actually sent me 38 amp batteries for $40. Cant beat the price.
    Visit this site
  8. donanton
    donanton Member
    sweet thanks ill order that one right now
  9. donanton
    donanton Member
    too late. those ps 6360 batteries are discontinued. :(
  10. donanton
    donanton Member
    The guns are built, just need to do the hose and solenoid plumbing.
  11. donanton
    donanton Member
    I have the bricks
  12. donanton
    donanton Member
    1st question: Does anyone have a picture of how their electric is set up from their batteries to their ESC?
    2nd question: does anyone know of a somewhere that I can order an expansion chamber for my guns?
    thanks
  13. Evil Joker
    Evil Joker Member
    battlers connection has um http://www.battlersconnection.com/html/fittings.html
  14. donanton
    donanton Member
    Where did darticus get the powerpoles? I saw the info page, but not a page to buy them.
    Thanks.
  15. SnipeHunter
    You can buy them at tower hobbies.
  16. donanton
    donanton Member
    Got 40. Besides Visit this site where can I get wire in bulk? THey dont have any black wire but I dont want to pay extra shipping.
  17. Evil Joker
    Evil Joker Member
    check here for powerpoles http://www.universal-radio.com/catalog/parts/2228.html also ebay has some good deals like a buck a pair
  18. donanton
    donanton Member
    Visit this site has wire cheaper than darticus found it. $0.35 per foot of 14 gauge.
    Before I order it, Is there a direct correlation between gauge and volts? I ask since there is no mention of the voltage that the wires at Visit this site are rated for.
  19. Tugboat
    Nah, the voltage rating is dependent on the insulation type, not the wire gauge. Almost anything will carry 12V, 6V is easy! :)
  20. donanton
    donanton Member
    BIG PROBLEM TIME:
    I have the esc hooked up to the battery correctly and the motor connected to the esc correctly. When I turn the ESC on and have the motor channel at neutral, the motor goes to full power and the only way to stop it with the receiver is to push the joystick to full positive signal.
    I am using an Mtroniks viper marine 40 reversable ESC with a sombra labs SL-8.
    Any suggestions?
