watertight
Discussion in 'General' started by dman10, Aug 18, 2011.
  1. dman10
    dman10 Member
    would it be legal 2 put watertight compartments like in the titanic?
    Titantic had watertight compatments?
    Humor aside... you can put in a watertight compartment for the electronics, but apart from that, compartmentation is illegal in most of the clubs that battle.
  3. Knight4hire
    Knight4hire Active Member
    I didn't know that the Titantic had water tight compartments!
    Water tight compartments for electronics is OK, but the compartment needs to be as small as possible, and not give the ship buoyancy.
  4. rarena
    I think the open tops negated the watertiteness. Hense the reason it sunk....
    Priceless, how'd they miss that one???
    never battled combat
  5. dietzer
    dietzer Admiral (Supporter)
    They didn't miss it. They did it on purpose. They didn't think a worse case scenario could happen (massive leaks in more than 5 watertight compartments), so they chose to save money by not having the watertight bulkheads go all the way up...
  6. rarena
    The Titanic built to save money????
    Epic Fail
    see what happens when you cheap out
  7. Anachronus
    Of course they did go all the way up on Brittanic and a mine took her out quite quickly.
  8. DarrenScott
    Only because the portholes were left open to "air" the ship out, in preparation to receive casualties.
  9. Anachronus
    Indeed, still if given the option I'd choose Olympic
  10. Sinkazuki
    Sinkazuki Active Member
    Colorado
    Titanic sunk because Leonardo de crapo was a wus..
    Eddie Haskell
  11. WillCover
    WillCover -->> C T D <<--
    Harrison, Michigan
    Randy you're as bad at digging up dead post as those grave robbers digging up the ships in the Pacific:laugh:.....did you get goats yet?
  12. NickMyers
    if we're going to necro threads, could we at least necro useful threads with relevant content?
  13. Lou
    RANNNNNNNNNNNNNDDDDDDDDDDDDYYYYYYYYYYYYY!!!!!!!!!!!!!!!!!!!!!!
