WCC Fleet Status?
Discussion in 'Washington Cascade Column' started by NickMyers, Mar 30, 2010.
  1. NickMyers
    Not sure where he lives, but if its up my direction I can run over to his place and pick it up if you let him know and tell me where to go.
  2. Hovey
    Hovey Admiral (Supporter)
    Washington
    The Westfalen survived sea trials today. Tomorrow I will check to see if the repairs to the gas system are holding or not, but it looks like she will make it to battle.
  3. NickMyers
    Thats great news! It'll be good to have you on the pond, though I hope youre on my side, since i can't hit the Westfalen unless I run it over...
  4. phill
    phill Active Member
    The Mogador passed static tests of all systems for the first time!
  5. NickMyers
    Suffren has been patched (and had half a panel replaced) and has been repainted. All systems have been re-tested and are ready.
    I believe I have solved the electrical problems of the Maru, with some luck and some time it might actually see the water next week for more than 2 minutes.
  6. GregMcFadden
    karlsruhe suffered a bit o minor damage in teh move, it is repaired. Now she needs the waterline installed and two deck tiedowns, along with a recovery float to be 100%
    -Greg
  7. tgalx3
    tgalx3 Admiral (Supporter)
    Snohomish, WA
    Bismarck is ready to go. swapped out all the guns. I should get the 5th from Phill at the Battle. Trying to figure how to put dual sterns in this ship is proving much more challenging than one thought.
  8. NickMyers
    Fitting it in or controlling it?
  9. Hovey
    Washington
    I am sure there would be a lot more room for duel stern guns without that extra pump you have
  10. NickMyers
    Then he'd have to find room for another gun though.
  11. Hovey
    Washington
    At least we could sink him without having to resort to galley tactics.
  12. NickMyers
    I wonder how big of a hole it would take to overwhelm those pumps.
  13. Hovey
    Washington
    I shall start training the galley slaves immediately!!!
  14. NickMyers
    I've found some plans that may be of use to us
  15. tgalx3
    Snohomish, WA
    Is the Bismarck really that bad you would resort to that little toy?
  16. NickMyers
    Its not the Bismarck itself we object to. Its the spending 2 units on pumps in it that amuses us so.
  17. tgalx3
    Snohomish, WA
    Well when I bought the ship and built it I was all moto and planning to go to NATS and all that. I also knew that people like to go after the big ships so I made sure I compensated for that.
  18. Hovey
    Washington
    Those are so small we would need a fleet of those little things and hope you foul your props running over them. Then we could swoop in and get you.
    Alex, the rules say you can have two pumps so you are totally legal and within your rights to have them. But you should also realize that given how few of us there are you are basically unsinkable without ram damage. So I don't object to you having two or even six pumps but that doesn't mean I wont tease you a little about it either.
    Real men don't need pumps!
  19. NickMyers
    No pump? That worked realllll well for the Westfailing.
  20. Hovey
    Washington
    Actually, one thing I forgot to check on her is which way her pump is spinning. If it is backwards then that would explain why it doesn't always prime.
