We realy need a battery section Battery question
Discussion in 'Electrical & Radio' started by Powder Monkey, Jul 30, 2008.
  1. Powder Monkey
    Okay ran with the lead cell at NATS and need to change to heavy looking to swap over to NIMH I run at six volts what is my best option (do your best Shultz impersonation here) “I know nothing” about NIMH I need the how where and why let the schooling begin
    Thanks again Guys
    Monk
  2. SnipeHunter
    What size batteries are you currently running and how much do they weigh?
  3. Powder Monkey
    I am currently running a WERKER WKA6-7.2f it is 6 volts 7.2Ah it weighs 2.8lb [V]
    Is that all? Shoot. I thought you said it was HEAVY...
  5. Powder Monkey
    LOL for my little rowe boat it is [:D]
  6. SnipeHunter
    If you want to stay with SLA batteries I think eagle picher or someone makes some nice 6V 5ah cells that are pretty small, not sure on the weight but I cant imagine it not being lighter.
    But since it sounds like you want to run NiMh a 6V 10Ah pack would work pretty well for you. I think that would save you somewhere close to a pound and give you more juice. If you want to save more weight you could always go for smaller cells but I dont know what the weights for those would be like.
  7. Powder Monkey
    No I want to go to NIMH for weight dispersion and size
  8. BoomerBoy17
    I thought that the NIMH batteries were the most expensive. Are you sure you want to go that direction Monk. ive also heard alot of good things about SLAs.
  9. Powder Monkey
    lipo is the $$ hog and yes i'm sure
  10. BoomerBoy17
    Oh, ok, Im sure you know what ur doing, it'll work out.
  11. Lou
    Lipo goes BOOM when mixed with water. NimH is the way to go.
  12. Powder Monkey
    Okay so back to the question what do and were do I get it ?
    Come on bouys spill ya guts
  13. crzyhawk
    I think most of the NiHM packs that guys run are 7.2 volts, which if you run your RX off your main battery would probably make it let out the magic smoke. I'm not sure where guys get them, but you could probably google the batteries and do some price comparisons, then post what you find and see if anyone has had bad experiences with that brand of battery.
    I'm interested myself as I am looking at putting NiHMs into my Salt Lake City and my Belleau Wood. if I like them, I just might look at replacing the SLAs in my battlecruisers with NiHMs as well.
  14. Powder Monkey
    no one wants to let the cat out of the bag on this one ayy
  15. rarena
    Powder, I make all my battery packs out of walmart nimhs soldered together. If anything I recommend looking for larger amph ratings, the bigger the number, the longer it lasts. Scotchcote for water protection.
  16. Powder Monkey
    Rob what did you make yours at 5@ 6V or 6 @7.2V or more?
  17. Powder Monkey
    http://www.cheapbatterypacks.com/cellinfo.asp?invid=ELITE1500A
    Looking at these ones what do you think ?
  18. djranier
    Capacity is very low, go for a sub C, or C, thats 4000 mAh or more.
    Are you looking for packs, or single cells, that you are putting together?
  19. SnipeHunter
    Whats wrong with a 6V 10ah pack? Those seem pretty popular. How much weight are you looking to drop? You shouldn't need 10ah for a cruiser, closer to 5. Building your own packs is fairly easy but I'd still reccomend buying them depending on how good at soldering you are. 7.2V packs are easy to get since thats what a lot of model car guys use. If you want better weight/balance maybe go with running two ~3000ah packs at the same time so you can put them where you want/need the weight.
  20. Powder Monkey
    Weight me personally around 50 lb oh the ship if I could drop 1lb or so enough to play with Lead in the bilge in mid line would be sweet [^]
