What brushless esc do you use?
Discussion in 'Electrical & Radio' started by Jordan Jones, May 11, 2016.
  1. Jordan Jones
    Jordan Jones Member
    Hi guys I was just wondering what brushless motor controller everyone uses. I noticed many of the controllers I have seen in builds have a braking feature. Do you just pulse it reverse twice to combat that or is there a an alternative motor controller that doesn't have that? Thanks in advance
  2. thegeek
  3. NickMyers
    if you cant disable the brake it is generally viewed as too much of a PITA to use. (and in practice, they're a giant PITA). The HK ones you see in common use here can have the 'double tap' disabled via the programming. That said, if you plan to battle in a format where utilizing reverse is considered shameful, heinous or outright against the rules, the double tap requirement likely isn't much of an issue, because you wont be backing the props anywhere near as often or in such need of hurry as in fast-gun.
  4. Jordan Jones
    Jordan Jones Member
    Alright thanks, also as for low voltage cut off. I assume you just check your batteries before starting, or do you have some other way to monitor it?
  5. thegeek
    Low volt is set in the controller and it has .1 volt rez. so you are covered.
  6. Jordan Jones
    Jordan Jones Member
    Yeah but I mean don't the escs shutdown when they hit the lvc? Or do you assume the fully charged battery will last long enough?
  7. NickMyers
    You don't need to assume, you take some measurements, get some numbers, and do some math.
    Loading lifepo4 in my current battlecruiser, i can pack in 40AH. Conservatively I mentally lop off 10% or so of that and assume i have about 36AH capacity. I know how much my drive and pump motors draw and can make an educated, though generally exceedingly conservative, assumption about how much time I have on the water total.
  8. Jordan Jones
    Jordan Jones Member
    Alright. Sorry for so many dumb questions, but what would you suggest as a time target?
  9. NickMyers
    not dumb questions
    My general view is 'pack as much battery power in as possible'
    Locally (for me) sorties can run anywhere from 10 minutes to 30ish (rarer lately), and fast-gun rulesets allow for changing batteries between sorties. So if you expect that your maximum time required of your ship to be on the water without a battery change-out is 30 minutes, I would add 15 minutes to that and plan that I need at least 45minutes of run time. YMMV of course, and if you're building something weight sensitive like a DD you might cut the margins tighter and keep a closer eye on matters. If you're building a battleship you probably have weight to spare to heap in extra power above and beyond.
  10. Jordan Jones
    Jordan Jones Member
    Ah alright thank you. I guess my big gun brooklyn just became more complicated, but I will make it all fit even if it kills me haha.
  11. NickMyers
    if I remember most of the big-gun stuff I've seen and read, your power consumption rate should be lower than in fast-gun. Not sure on their sortie times though. Definitely ping some active BG folk and ask if they can share their numbers with you.
  12. Trey Schultz
    Trey Schultz Member
    Md
    Nick,
    From what i have seen from amp curves, you should probably hack off 25%. Check for the Amp Curve data online.
    Regards,
    Trey
  13. NickMyers
    are you referencing capacity loss from aging, cycling or simply not being able to realize rated capacity before dropping below minimum voltage?
  14. Trey Schultz
    Trey Schultz Member
    Md
    Voltage loss.
    http://sustainableskies.org/wp-content/uploads/2010/10/typical-lifepo4-discharge-curve.jpg
    I am sure you have seen what happens to an over-discharged Lithium battery.
    on a 2.5 ah battery, it hits puff mode at about 2 ah, so 20% add 5% for safety til 25% for my recommendation.
    I also take advice from a master electrician who recommends only calculating for 60% (ah) use. (Meaning 40% left)
    Just my 2 cents.
    Trey
  15. NickMyers
    this is the curve for the cells I'm using. A bit more favorable, though no doubt after a few years it doesn't look quite so, and it definitely depends a bit on how low you consider acceptable. If you're fine going down to 3v/cell then you're close to 90%. But I like your number of 20-25% buffer better, it sits well with my paranoia of losing a ship for lack of power.
    Trey Schultz likes this.
  16. Trey Schultz
    Trey Schultz Member
    Md
    I don't want to accidentally blow up a battery
  17. rcaircraftnut
    Oklahoma
    The life packs are much less prone to damage from over discharge than the lipos are, but it's still best to keep at least 10% charge as a minimum on them. They also have a great discharge curve.
  18. NickMyers
    ESCs with voltage cutoffs are a good step then
    Trey Schultz and rcaircraftnut like this.
  19. rcaircraftnut
    Oklahoma
    Also the life batteries are far less prone to fire, puffing, or "blowing up" than the lipos are. That said, I have puffed a few lipos, but never blew one up. The only fire I ever had was due to a puncture in a lipo.
  20. Trey Schultz
    Trey Schultz Member
    Md
    Oh I have those as well ;). Since I haven't tested the cutoffs, I don't want to find out they don't work 10 minutes into the second sortie as i am going on 5.
    rcaircraftnut likes this.
