why wont it work!!!
Discussion in 'Electrical & Radio' started by uss Johnston 557, Aug 9, 2013.
Thread Status:
Not open for further replies.
  1. uss Johnston 557
    uss Johnston 557 Member
    I have a duel motor setup with two ESC's a 6CH spectrum receiver two 6V 2200mAh battery packs and a HP6DSM E-Flight transmitter, but after I plug the battery packs into the ESC's and try a little throttle the ESC's start beeping 1 beep per second or so and the motors don't run while me servo is running fine, meanwhile my battery packs start to heat up and sometimes start to smoke. I have tried allot of stuff but still haven't figured it out.:(PLEASE HELP!!!!!
  2. absolutek
    You pulled the red wire from one of the esc plugs that goes into the rx right? You can only have one esc powering the rx, assuming you aren't using a seperate battery just to power the rx. Mind you, I don't think it would cause your batteries to smoke if you forgot (though, I could be wrong).
  3. uss Johnston 557
    i did remove the red whire from one of the ESC's
  4. absolutek
    did you attach the right wires to your motor(s)/batterie(s)?
  5. uss Johnston 557
    yes i belive so:ermm:
  6. absolutek
    Take a picture of your setup all rigged up (assuming it won't smoke or explode) and post it here.
  7. uss Johnston 557
    haha lol ok I will
  8. uss Johnston 557
    ill post a video on YouTube and show what's going on and then ill post a link on here to the video :)
  9. absolutek
    Next time don't post two different threads either.
  10. uss Johnston 557
    http://m.youtube.com/watch?v=ZjXltXvqgW0&feature=plcp span>
  11. Tugboat
    I am closing this thread, please everyone reply in the other one.
Thread Status:
