why wont it work!!!
Discussion in 'General' started by uss Johnston 557, Aug 9, 2013.
  1. uss Johnston 557
    uss Johnston 557 Member
    I have a duel motor setup with two ESC's a 6CH spectrum receiver two 6V 2200mAh battery packs and the HP6DSM E-Flight transmitter, but after I plug the battery packs into the ESC's and try a little throttle the ESC's start beeping 1 beep per second or so and the motors don't run while me servo is running fine meanwhile my battery packs start to heat up and sometimes start to smoke. I have tried allot of stuff but still haven't figured it out.:( PLEASE HELP!!!!!
    What motors, what ESCs, please :) A pic of how you have them connected would be helpful, if you can lay them out on a table and take a pic of it.
  3. uss Johnston 557
  4. uss Johnston 557
    ill post a video on YouTube and show what's going on and then ill post a link on here to the video :)
  5. uss Johnston 557
    http://m.youtube.com/watch?v=ZjXltXvqgW0&feature=plcp p>
    By any chance, did the ESC come with a manual? I'm wondering if it matter which red&black wire pair goes to the battery, and which goes to the motor. It usually does. Not saying you have them backwards, but I like to check everything obvious first. Jadfer's advice on youtube (get one motor/ESC/battery playing nice, then do the other one) is good advice. When you hit a snag, simplify :)
    Nice looking boat, though!
  7. uss Johnston 557
    Thanks,
    No the ESC's didn't come with a manual [​IMG]
  8. absolutek
    The ESC's could just be bad. I would try them out one at a time.
  9. uss Johnston 557
    I have i does the same thing
  10. uss Johnston 557
    do you want me to do another video and show how everything is connected?
  11. Tugboat
    I have an out-of-the-boat question... I saw in the video that your Transmitter voltage was reading 5.5V... Most transmitters run on higher voltage (like 9.6 or 11.1). Is your transmitter fully charged?
    In the boat, have you made sure that the batteries are fully charged? When you short-circuit the batteries (smell a funny smell or God forbid, see smoke), they've been heavily discharged and should get a nice gentle charge back to fullness.
    As for the ESCs, There is some truth to 'you get what you pay for'. A 320A ESC should cost probably 10-20 times what you paid for those, and would have a much bigger heat sink for the power transistors. Honestly, the 30A ESCs on my battleship have bigger heat sinks than the ones you're using, which makes me wonder if the seller is selling something that isn't what he says it is.
  12. jstod
    Why do you need two ESC? If it were me, I would wire the motors up together and run them off one ESC. I would suggest one of the strike models ESC simply because thats what I use and it has never failed me, And it is water proof. just my thoughts. The ship looks real nice, hope it gets up and running soon!
  13. absolutek
    Redundancy. Two is always better than one. Of course, only if they work.
  14. uss Johnston 557
    whan I first got the transmitter it read like 6.1 or 6.2
  15. uss Johnston 557
    and yes the batteries have been fully charged
  16. uss Johnston 557
    I just put new batteries in my treamitter and it still reads 6.4 volts so.......?
  17. uss Johnston 557
  18. mike5334
    If it is a 4 cell transmitter, then 6.4 is what it should have and could probably go as low as 4 volts without any issues. :)
  19. uss Johnston 557
    Yep it's a 4 cell
  20. jadfer
    Did you put up a video showing the wiring in detail? so we can see where each individual wire goes? Do that so we can help you ok.
