Why won't my motor work??
Discussion in 'Propulsion' started by metaphysics1221, Apr 30, 2008.
  1. metaphysics1221
    metaphysics1221 Member
    I am using two of these motors:
    http://www.allelectronics.com/cgi-bin/item/DCM-229/400200/3-12_VDC_MOTOR_.html
    I have been hooking them up to a wall transformer which supplies 9VDC at .8 amps. I have tried other power supplies up to 15VDC at 1.2 amps. At the higher volt/amp level it started turning in short 90 degree jerks but never the way it should. Can anyone see something I am doing wrong??
  2. GregMcFadden
    You may be overcurrenting you wall source. Remember, those current values are when the motor is spinning relatively freely. There is a large current spike when you first start the motor. Hook them up to a battery and try it. The other option is a Bum motor (Dead).
    -Greg
  3. metaphysics1221
    Thank you! I hooked it up to a battery and it runs fine :)
    Those motors eat current like there's no tomorrow, It takes 4 AA's each to keep them happy :)
