Wiring help? 6 Volt 4.5 Ah Sealed Lead Acid Battery
Discussion in 'Electrical & Radio' started by NASAAN101, Jan 8, 2011.
  1. NickMyers
    I don't actually have one, but I lurk over at RC-Groups in their ships sections and people who use them seem pleased over there, so if they work out (or dont), please post a review thread.
  2. NASAAN101
    Guys,
    Before i could order one, they got sold, out, so for now I'm looking at just doing the MAG throttle, But they one i had died on me, how do you build one???i have the two 10amp swiches, and the servo, i'm just not sure how to do it!!!
  3. jadfer
    http://www.mwci.org/howto/Images/destroyerelectrics2.html
  4. NASAAN101
    Hey Jadfer,
    That's for that!!! But the MAG throttle, is only running the two motors i have in my LST!!
  5. NASAAN101
    Guys,
    Dose anyone have or use the MicroViper Marine10, I'm not going to get it just before the season starts in 2012! There were i found it: http://www.loyalhannadockyard.com/VIPER.htm. Thanks guys,
  6. buttsakauf
    buttsakauf Well-Known Member
    Garland, TX
    Strike Models sells the Viper Marine series as well. You can also look directly on the mtroniks site
    Mike Butts
  7. NASAAN101
    Mike,
    The problem with buying it off the mtroniks site is, it doesn't give you the US money, it's in pounds or British money! but I like the MicroViper Marine10, I know stirke has it to!!!
  8. Evil Joker
    Evil Joker Member
  9. NASAAN101
    guys,
    I wonder if the Micro Viper Marine10 would work with these batteries: http://www.batteryjunction.com/tenergy-6v-1600mah.html and what is the safest way to water proff these?
  10. DarrenScott
    Nikki, they are already waterproof.
    Yes, they will work quite well with that battery.
  11. NASAAN101
    Darren,
    I'm talking about the batteries :D???
  12. absolutek
    If you're getting a ESC, you may as well get a 7.2v r/c car pack with more capacity, say around 3000mAH or more
  13. NASAAN101
    chase,
    Other then that one there are six others: 1. http://www.batteryspace.com/nimhbatterypackcombotwo72v4200mahnimhbatterypacksmartfastcharger48-108v.aspx, 2. http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJA83&P=0, 3. http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLEW0&P=0, 4. http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXACFV&P=ML, 5. http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXXUP5&P=ML, 6. http://rchobbies.com.au/store/product_info.php?cPath=396_36&products_id=35395! any ideas???
  14. NickMyers
    There are a great many batteries and combinations in the world. More than you can possibly link to in this lifetime. Far more than we can possibly give advice on, even though there are more of us than you. So here is some advice:
    Figure out the space you have in whatever ship you're looking at (measure it!), how much weight you have to work with(weigh everything and compare it to your max weight), and find a battery/pack in the 6-7.2V range that has as much capacity as possible and will still fit in your ship. Buy 4 of that battery and a charger for it. Now you can run your boat,dinghy,ship,whatever all day long.
  15. NASAAN101
    Hey Nick!
    I wasn't trying to get anyone mad at me, I was just asking!!!
  16. KeriMorgret
    Seattle, Washington
    Nikki, a little more listening and a little less asking would probably help. There are lots of solutions that will meet your needs. Nick is telling you how to judge if a specific battery will meet your needs without needing to ask everyone if x particular model works for you.
  17. NASAAN101
    Keri,
    I understand!! If it sounded like i was bitching about it, i wasn't trying to ok!!! I'm just still so new with this, and i haven't taken my LST out on the pond yet!!!!
  18. pba
    pba Active Member
    dayton
    The polk esc's are no longer available. I have found 2 replacements at R2hobbies.com Both are 100 amp and 1 is waterproof they are $13 and $14 dollars I bought 1 of each and they seem to work great with no setup needed, they work just like a servo and follow the pulse so they will remember when the computer radio uses 40% for travel adjust to make speed.
  19. NASAAN101
    Guys,
    Question I was thing about getting the 12inche or 20inche servo extensions for both my LST and Doria that way, I can waterproff them and not worrier about pulling on the wires what do you guys thing? Let me know ok!
  20. mike5334
    Get whatever works, Nikki. If it is too long, then wire tie up the excess.
