WWI Kongo (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Oct 20, 2019.
  1. Mad_Modeller
    Mad_Modeller Active Member
    Edmonton, Alberta Canada
    Very nice. Keep up the good work.
  2. Anvil_x
    Just curious Kevin, but that aft Barbette, what's the plan to keep that sucker from flooding in long stern runs?
    At least that was my problem with Texas. Ended up fixing it with a plate and some silicone in the barbette to prevent it.
    I stopped drilling out my barbettes and just use a hole big enough for the cannon's neck now. What's your plan to address it?
  3. Kevin P.
    I'm planning to print the barbetts with the elbow holder, turret mount setup, and a solid layer covering the opening, so it will be sealed up. Aft deck will be attached with the 1/2" wide magnetic tape which has shown to be pretty waterproof
    I printed up the casement inset for the aft deck
    Measured and drew outline for the deck piece
    This is the general idea, need to cut the angle on the end pieces and glue it all together
    Sealed up the deck rim
    Also added magnets for the forward deck. These have worked well for me on the other builds
  4. ZARUBA1987
    ZARUBA1987 Well-Known Member
    Tarkington Tx
    Kevin your one talented guy.
  5. Anvil_x
    Nice. looking forward to seeing the mount!
  6. Kevin P.
    Thanks guys
    Couldn't really get past the stare-at-it-phase tonight. Here's the pump outlet tube arrangement
    The plan is to build the aft deck piece, add barbetts, then add guns/mounts. Solenoids will be attached to the deck, so that weight distribution will determine the internal arrangement of the bottle (mainly size), control box, and batteries. I think I have a good-enough plan to move forward tomorrow evening
  7. Kevin P.
    Worked on aft deck. Support underneath
    aft deck magnets
    rcaircraftnut likes this.
  8. Anvil_x
    Interesting how you laid the decks in relation to the step, that could really come in handy on my next boat.
  9. rcaircraftnut
    Oklahoma
    I hadn't noticed that before. I like it. Let the superstructure cover it up. Dang that's genius.
  10. Kevin P.
    Yeah, I’ve used that deck scheme on a few builds. This one is rock solid which is nice
    Printed first barb today. Ran out of abs so may wait for more to get the rest
    rcaircraftnut and Anvil_x like this.
  11. Kevin P.
    Work on aft deck
    aft magnets
    A barb
    good down angle for an A turret
    rest of aft deck wood
    with SS
    will be waiting for filament to print remaining barbs, will make guns and get aft deck together until then
  12. Kevin P.
    Epoxied deck
    aft deck magnets, part 2. Film between magnets to catch excess goop, line up magnets
    clamp deck down on glue
    waiting for magnets for last portion. Started making guns (not pictured) while I wait for abs
  13. Kevin P.
    Abs arrived, printed up remaining barbs and turrets
    Pleased with the turrets
    starting to look more like a ship
    Gooped the barbs in
    inside of barbs is solid except for tube holes (for flooding prevention)
    Next will be gluing the aft deck levels together. I also made up the guns, so I’ll start bending the mags and determine the mounts. Planning for all solenoids to be attached to deck for 1/8” tubing
  14. Kevin P.
    Starting to get guns set up
    Plan is to get the magazine caps to come out of the barbs. I’m 0 for 1 on getting the bends correct thus far
    Gooped the aft deck together
    next step will be getting the mags bent and adding holders under the deck, then solenoid mounts
  15. Kevin P.
    Aft deck finally together
    worked on bending mags
    fill ports accessible
  16. Commodore
    Commodore Well-Known Member
    Sunny TX
    That's looking really good - you tempt me to buy another boat I'll never finish. :p
    Meanwhile - what kind of printer are you using? Is that ABS or (?), and how is it working out for you?
  17. Kevin P.
    Thanks Chris. I have a Qiditech dual extruder, and yes that's ABS. It's working out pretty well, I've been pleased with the ABS durability. Some of the sections that will be exposed to fire will get a layer of fiberglass cloth
    Props on
  18. rcaircraftnut
    Oklahoma
    Been looking at that new Hermera extruder pretty hard myself. Still not sure what way I want to go yet.
  19. Commodore
    Sunny TX
    Good, I like ABS, but I really need to build an enclosure for my Prusa - when the air conditioner/heat is running, funny (not funny) things happen sometimes. I'm trying some new PLA+ that I found on Amazon for my new Scheer superstructure. Hopefully it will be good enough for cruiser work. (And hopefully I'll get to play with it at Nats this summer) The Seydlitz is getting a new SS printed with TPU. Huzzah.
    Anyway, carry on - have a good weekend, etc.
    By the way, Mr. Beckett would approve of your brazing-fu.
  20. Kevin P.
    More photos from weekend. Cleaned up props post brazing
    now to make some rudders
    Made magazine mounts
    fwd side has solenoid mounts too. Still need to figure out plan for aft solenoids
    Lou likes this.
