WWI Kongo (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Oct 20, 2019.
  1. Kevin P.
    Forward solenoids
    Aft solenoid mount. cradle for two solenoids
    suspend under mags
    Kinda a PITA to get solenoids in, think it will be ok
    now that guns are in I have a decent idea where the rest of the insides will go from a weight distribution standpoint. Continuing to chip away, have some finish epoxying to do on deck, need bottle mount then probably hoses, battery mount (already printed), rudders. Planning 4s 15Ah batteries (same as Agincourt). Radio box will be my standard interchangeable with Agincourt, Missouri, and Seydlitz
  2. Kevin P.
    Bondo on the turrets
    layer of cloth on outside
    Cloth over the printed parts
    rcaircraftnut and Panzer like this.
  3. Kevin P.
    Got some paint down. Focusing on getting the other boats ready, then will put more direct effort into this one
    mounting SS and internal armor are next
    rcaircraftnut likes this.
  4. rcaircraftnut
    Oklahoma
    You ain't the only one painting today. Lol. Repairing the SS first though while the hull dries.
  5. Anvil_x
    went into a fight against Tyler's triple-sidemount Derf this last weekend.... these triple sidemount battlecruisers are going to be AMAZING. he made a pass on me with his heavy side and peeled me open like a beer can. then, as I limped back in, Texas started keeling over and sprayed everybody in the pit with bilge water.
    it was totally unintentional, but wow was it funny. can't wait to see video if this sucker in action.
  6. Kevin P.
    Finally got the bulk of the SS glued
    Should start progressing again this weekend. Nats is creeping up
  7. Kevin P.
    Made small amount of progress
    Solenoids mounted
    Rudders and rudder servo in
    props/rudders. The class 4 rudders are small for a boat this long. in hindsight should have gotten pivot point closer to props
    Tested internal Layout. About 21 lbs, looks like forward/aft balance will be good
    Next step is wiring and hoses. With no test switches and just one pump the wiring will be pretty simple. Maybe seaworthy by end of next weekend
  8. Kevin P.
    Able to get more time dedicated to this one
    CO2 hoses in, pretty simple
    got through about 2/3 or wiring tonight, will finish tomorrow, plan to get her operational by the end of the upcoming weekend
  9. Commodore
    Commodore Well-Known Member
    Sunny TX
    (sigh) I remember once upon a time when I was young and productive.
    Maybe I'll get some boat work done this coming weekend...
  10. Lou
    And check or get some new batteries while you are at it (wink wink nudge nudge)
    Commodore likes this.
  11. Kevin P.
    Wiring done. Plugged into box, guessed right first try on servo leads out of the box. lack of pump switches and test switches made it much simpler than most of mine
    Everything tested out which was good, auto switch worked
    also finished making barrels
    Next step is testing guns, gluing in some internal mounts, then sheet and sea trials. Also need to get the turrets flush and those magnets in
  12. bsgkid117
    Looking great, as always. Those Kongos are going to be killers I think. Not quite sure where I've ever seen a boat like that before, it seems really familiar to me but can't quite place it...
  13. Kevin P.
    Not exactly sure what you're referring to Will, but the internal layout is same as Agincourt (which is basically the same as Seydlitz). Now I have 4 boats that use a common control box, and two boxes, which makes swapping between primary boats easy
    Here a shot of the wiring. Looks like small spaghetti but really not too bad
    Aft wiring, ESC in the waterchannel for cooling, also auto switch and level (cylinder with cork)
    Battery mounts. One of them slid while drying, but should be fine
    13 sheets of balsa prepped for this boat, Missouri, and 1 mid-nats resheet if necessary
    Sheeted. wasn't too bad. I was a bit too light on some of the super 77 so had some silkspan to balsa adhesion issues, which didn't show up until contact cement was applied, but think it'll be alright.
    Down to the last few odds and ends, hopefully wrap most up tomorrow, sea trials probably in the evening this week
    rcaircraftnut and bsgkid117 like this.
  14. Kevin P.
    Got her painted. Very smooth, critical aspect of the build
    initial waterline based on window depth
    Sea trials this week
    Currently 22 lbs, so I'll see what sort of ballast she needs to get down
    Nate G, Lou and Beaver like this.
  15. Kevin P.
    Sea trails today. overall balance was great, just needed a little weight in the bow and on starboard side.
    Turning was comical, pump was absurd, have a few kinks to work out but pleased overall
  16. Selley
    Selley Active Member
    Butler, W.A
    Wow, last time i looked on this thread, she was a plain hull
  17. Commodore
    Sunny TX
    Looking goot!
  18. Kevin P.
    Thanks guys
    Put some finishing touches on
    Added attachment points for hose and wires to the solenoids
    She looks pretty badass haha
    New rudders I'll try out tomorrow
    Stern aspect
    Came out clean
    Selley, rcaircraftnut and Beaver like this.
  19. Kevin P.
    I tried out the 4.5" rudders and she still didn't turn, so I decided to shift to 1.5" props. Previously I guessed throttle at around 25% to get on speed with the 1.75" props, so the 1.5's should be fine. It's a very sleek hull form
    Also decided to extend the shafts a bit. I overestimated the rudder size when I put the rudder posts in, so they were too far away from the end of the shaft.
    I popped the old bushings out and made up an extension piece
    Showing with the 1.5" Korts
    Extension piece. Stuffing tubes were sized for the 3/16" shaft, so had to sleeve two tubes to fit the bushing for 1/8" shaft. Also had to go to 48 pitch gears to fit the 1/8" shaft. I used the washer so the bushing flange would be in contact with the main stuffing tube. I think it came out well, but only time on the water will tell if it holds up
    Installed
    With new rudders, pivot point closer to the prop, I have found this to be important since when the boat is turning the face of the rudder will be closer to the prop. You lose a little of coverage on the outboard prop in a turn. Looking forward to testing it out
    Also added some skegs to help with rolls in the turn
    Hopefully test her again today or tomorrow, hopefully battle in PA
    Aye Blinken and Justin Ragucci like this.
  20. Anvil_x
    Looks like we had similar issues. Last week I pushed my 1.5" props 1/4" closer to the rudder using some extensions.
    Lead skegs?
