WWI Kongo (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Oct 20, 2019.
  1. Nibbles1
    Nibbles1 Well-Known Member
    Orinda, CA
    I agree, too bad it's going to get shot up :woot:
    Selley likes this.
  2. modelshipsahoy
    modelshipsahoy Vendor
    Michigan
    ...with tooling gel.
    buttsakauf likes this.
  3. modelshipsahoy
    Michigan
    So I’ve had this Kongo plug for a couple weeks. Just got a chance to open it up. Have a short week off the day job and going to get this mold moving.
    It had a little bit of shipping damage, but overall in good shape. Nice Work Kevin!
    Updates to follow
    52B1554B-15D7-4184-8736-00ED59870223.jpeg CB45CA00-E3CE-45FC-8DCC-FE197AE2499D.jpeg 541414E4-F451-4741-897C-EFD5A41465C3.jpeg E665D49C-2B47-4323-97B8-F0882289EEF5.jpeg
    rcaircraftnut, Lou and Kevin P. like this.
  4. Nibbles1
    Orinda, CA
    Awesome! Could I possibly convert it into a WW2 Kongo somehow?
  5. Kevin P.
    Not really. I am planning on possibly making a WWII kongo plug/mold in the future, but that wouldn't be until next year at the earliest
    Renodemona likes this.
  6. Bob
    Now with three sidemounts, even for the WWI one. That's an Allied ship , since Japan was Allied in WWI. Mostly just to take German islands for their own, but a good sneaky move.
    rcaircraftnut and Renodemona like this.
  7. Anvil_x
    Allied Kongos. Allied Kongos with three sidemounts.
    Tigers with three sidemounts.
    this will be interesting.
    I might have to build a fiberglass boat after all.
  8. Lou
    26 seconds in this fitting?
  9. thegeek
    24 both WW2 and WW1. Allied or Axis, kind of like a universal part.
  10. modelshipsahoy
    Michigan
    Very sorry for the long wait to get this mold rolling. Good steps forward today in my 14 hours in the shop.
    Deck lip attached
    2315C97A-2300-41A6-A16C-DB0497C7127E.jpeg 7C3BC7AB-2A1C-4B49-9E66-2F47B1EF99FE.jpeg
    Parting Board cut and fitted
    046B80E9-3683-4318-B26A-3F644174E464.jpeg 82FA794F-8088-4A96-A625-2E84A1D7A07C.jpeg E8D40D0F-323B-4727-9705-FD4E7EE8AD04.jpeg
    Parting board struts all fixed and square
    Indexing blocks installed.
    48AA04F1-4106-4BA9-83B3-938C0B878053.jpeg A8DFB33E-0007-46FE-A135-133E5383BA69.jpeg 1862413F-F061-4A03-9E73-E9D25B3423F9.jpeg
    Started on filling the lip gap with clay.
    Ran out of patience and was better to stop and get some rest. Goodnight Moon.
    Kevin P. and thegeek like this.
  11. thegeek
    Thin, thin bottom and real thick sides please!
    Wow after thinking about it, that applies to several things that are totally unrelated.
    Panzer likes this.
  12. modelshipsahoy
    Michigan
    Of course.
  13. modelshipsahoy
    Michigan
    3 LB of clay,
    05B0C503-E34E-47DA-B3E7-104E3B5D6DC9.jpeg 4 coats of pva, (after a redneck repair of my spray gun)
    And tooling gel is on the port side.
    Kevin P., Renodemona and thegeek like this.
  14. Caractacus Patt
    Caractacus Patt Member
    Granite Falls, WA
    I have limited experience with creating fiberglass hulls - what is the clay used for? Is it to fill crevices and resist the unwanted intrusion of epoxy? Beautiful work by the way, looking forward to the finished product...
  15. modelshipsahoy
    Michigan
    I use clay to secure the center parting board because I can pull the board and scrape the clay off clean without damaging the plug.
    The deck lip board had a hard time catching the true deck edge. So had to build up the board to hold the line of the decks top edge or molds and subsequently parts will all be wonky lipped.
    I’ve built entire molds of nothing but clay
  16. modelshipsahoy
    Michigan
    Gel needs to be thick and I let this cure in what turned out to be the wrong position causing a drip edge on the casement decks. 13915262-2340-4FA7-97BA-73ADA6C2B688.jpeg
    So I had to define the edge with a tape line and surgically grind it off with the Dremel on high speed. A very trying process without cutting into the plug.
    F143DCF4-7F8F-429A-B240-AEBE80BF92AE.jpeg 38D43D5B-D06D-447C-90B0-F30C66CDDEAE.jpeg C346D4A0-5B43-4C20-97CD-9D17EC974656.jpeg
    I then cut some fine pieces of glass to lock in the beautiful casement work Kevin did making this plug. When this cures I’ll be shooting the whole thing in black for a wear indicator to the mold surface
  17. modelshipsahoy
    Michigan
  18. modelshipsahoy
    Michigan
    Port side skinned solid enough to remove the parting board tomorrow and start on the Starboard side. Things should move pretty quick now 5560F76D-4ED3-408C-A3BF-27FE63B638C0.jpeg
    Lou, thegeek and Kevin P. like this.
  19. modelshipsahoy
    Michigan
    In a “better safe than sorry” move, I added ribs (in my dress clothes on my lunch break) before attempting to pry the parting board away from the port side later tonight.
  20. modelshipsahoy
    Michigan
    Pulled the parting board.... putting my blood sweat and tears into this one
    A9C030AD-C9E4-437C-82C7-2A512CD35855.jpeg 4F37E974-4731-4BEA-9CB2-F2ECC1DBC848.jpeg DFF6659A-0278-43FC-B260-D8670630D339.jpeg 50E2B47E-0BAC-4C70-AEB0-B83AA9660F4B.jpeg F0F5F6E7-D264-4731-B23A-EA57B7BB5D73.jpeg E2BD06DD-5D48-44E8-AEFD-9DAC71CBD5E6.jpeg
