WWI Kongo (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Oct 20, 2019.
  1. Kevin P.
    Got down to the pond today
    Will have no issue getting the freeboard to a minimum. This was at about 24lbs
    at max weight I think
    looks like I didn’t make the bow full enough to displace the correct amount. Next step will be windows
    modelshipsahoy, Renodemona and Beaver like this.
  2. daisycutter
    daisycutter Active Member
    Careful in the stern as when underway she loves to suck down. Ok leave it alone people.
  3. daisycutter
    Looks great though. Banzai!!!!!!!!!!!
  4. jadfer
    Are you talking to yourself? You are weird....... just putting that out there.
    Lou, thegeek and Renodemona like this.
  5. Kevin P.
    Still focusing on other builds but was able to cut out most of the windows today
    about 1.5 hours later
    still have to do the casements. Top edge needed some loving to get the two sides matching. Pretty thick hull, not Courbet-thick but better than average. The glass seemed softer than what I’m used to. Lost a few chunks which was unexpected, seems like adhesion isn’t what I’m used to. Will be interesting to see how she holds up to bbs
    look at how smooth the cut outs are. Such a critical part of the build
    so important that they ended up the same place as other cut outs...
    next will be casements, then shafts/motor mounts
  6. Kevin P.
    Cut out casements.
    Innermost layer of glass has very poor adhesion, delaminates upon any disturbance, seen here as the white fibers. Something I have not seen before
    casement pictures
    casements are missing filler or chopped fibers, leading to several areas of gel coat separating from the glass. not good to be taking pre battle damage here
    there will be a lot of bondo in this hulls future unfortunately. For future hulls, casements should be backed by a lot of filler, ships used for battle can’t be this fragile
    Also got motor mounts in, my standard setup
    Need to get higher quality electrical tape, a lot of of adhesion issues causing run away filler
    next will be glassing around the shafts and struts
  7. bsgkid117
    Those fiberglass issues are disappointing. I am not very experienced with fiberglass, what are your corrective measures going to be? You mentioned bondo, but I thought it didn't really like water all that much? Epoxy + filler? More glass cloth + epoxy?
  8. modelshipsahoy
    modelshipsahoy Vendor
    Michigan
    We have learned so much about how to build this hull better since I made that one. Those casements are tight together and very sharp in the corners.
    Original instructions from you were that we should not worry about voids or flaws in the glass for the Combat Models... so we didn’t go back and grind open and fill the bubbles. Now very much wishing I did. Will send another if you are not happy.
    We now cut relief slits in the fiberglass skin and 1st sub layer then let that cure and sand the hard edges to prevent any bubbles or voids under the skin. Now, after building nearly a dozen of these, they come out very nice with no voids in the casements.
  9. Kevin P.
    Might want to check the convo history on that one...I did say rough surface is fine, sorry for not clarifying that rough surface being acceptable did not mean that voids behind the glossy gelcoat were acceptable, would have gladly cleared that up to prevent a subpar product going out. Fundamentally, having hidden voids doesn't make sense for a combat application - balsa only attaches in a few locations. If those locations are just gelcoat, it's not going to work under fire. Casements take a large amount of abuse because they are solid area on the hull. Hulls without gelcoat hold no secrets ;)
    I do appreciate the offer for another hull but I wouldn't ask for that. I'll be able to get this one closer to my standards, just more work that wasn't in the build schedule. I'll have to grind out all of the cavities and fill with epoxy + microfibers. It will be a pain to control the filler on the curved surfaces of the casements, especially since I already sunk the time in making solid casements for the plug, which is why I mentioned Bondo. I would put a layer of cloth and epoxy over the bondo. I still have the casement template kicking around that might come in use. The thin curved surfaces on the casements will be back-filled when I put the deck in. Maybe 2-3 hours of additional work for a 100 hour build isn't a big deal.
    Back to the workshop. I'll take some pictures of other casements I've made to give a better reference of what 'solid' looks like
  10. Kevin P.
    Casements on Fuso. Rough surface
  11. thegeek
    I infused some super thin CA to the area, well really the whole parameter.
    It stunk like hells door, causing near blindness. But it seemed to work?
    Open the window next time.
    rcaircraftnut and Kevin P. like this.
  12. rcaircraftnut
    Oklahoma
    Thin ca has been and continues to be my go to for fixing voids ECT in glass. Also I find clay to work better than tape for controlling runaway filler.
  13. Kevin P.
    What clay do you use?
    Tape has held up over the years, just looks like I found the line between 'good enough' and 'not good enough' is about $1 a role, oh well (to the grab bag pile)
    Motor mounts
    Now shafts and struts. had to do in two parts to get adequate filler below mounts
    Also did bow featherlite because i was mixing a batch
    epoxy job with better tape
  14. Beaver
    I myself use plumbers putty a lot to contain epoxy and other liquids. Works well but it a little oily. It's what i have on hand.
  15. Kevin P.
    Little bit of work today. Checked out prop setup. Will be using prop shop 1.7”
    cleaned up inside
    some rough layout
    next will be waterchannel and rudders
  16. rcaircraftnut
    Oklahoma
    Usually just molding or modeling clay. Play dough works but it's not cheap lol.
  17. buttsakauf
    buttsakauf Well-Known Member
    Garland, TX
    I like bondoglass for fairing in voids and curves. It is easy to prep, apply, and shape. If you slice off the excess (x-acto knife) when it is half cured and sand it down with 80 grit or so it will get you 95% of the way there. After it cures it will be virtually indestructible. Another light sanding and a layer of epoxy seals it good. I always use it around shaft exits for strength and aesthetics.
  18. rcaircraftnut
    Oklahoma
    Hadn't thought of that. Sounds like a good way to go. That's what I like about you guys. You are full of good info but still take suggestions. Awesome.
  19. modelshipsahoy
    Michigan
    I’ve been sick for a couple weeks now struggling with a double ear infection. It’s put us pretty far behind in production and kept me from my hobby as a typist here.
    But today I’m building a Kongō. I wanted to show you what we’ve learned about this mold and how to make it right with no casement voids. Our sincere apologies for the misunderstanding of the importance of this issue.
    We now use finely chopped glass that will lie wherever we put it without drawing air in over the peaks and valleys. Once that cures, we sand the surface soothe and lay in the armor belts upon assembly of the halves.
    0BCFA3A2-9019-4A36-A87D-BD896E51FDB7.jpeg CF41F5E2-9912-4259-94C4-2AD7B87895C0.jpeg
    rcaircraftnut and Panzer like this.
  20. Commodore
    Commodore Well-Known Member
    Sunny TX
    Looks great - casemates are the worst thing to deal with ... in many ways.
    modelshipsahoy likes this.
