WWII Scharnhorst (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Oct 14, 2020.
  1. Anvil_x
    Ok cool, I did pretty much that, but with a likely inferior tape.
    See how she turned out. the timing for the rudder rule change was right when I ripped out the shafts, so I'm gonna get the most out of both now.
    Hopefully this'll cure the Puking-Dog Turning radius problem!
  2. Kevin P.
    Haven't been able to put much time in recently, hopefully will turn that around.
    Working on smaller jobs -
    Bilge keels on today
  3. Kevin P.
    Drew up barbs and turrets today, will need some tweaks
    epoxied deck rim
    post for pump mount
    also coated deck pieces with same batch, got deck magnets in
    Will be printing remaining turrets and barbs tomorrow, benefits of work from home. Once those are in I’ll make up and mount guns
  4. Kevin P.
    Printer was banging away most of the day. Same mounting setup as Kongo, magnets in turret and barb
    always like getting barbs and turrets staged
    Had to pull spacing in based on turret shape
    forward barbs, relatively quick change from Kongo files
    I like the way the turrets came out, large turrets are convenient
    Next step is gluing barbs in
  5. Mark41
    Mark41 Active Member
    Orillia, Ontario , Canada
    I like to progress you're making.
  6. Kevin P.
    Haven’t been able to spend much time working on the boat, but I have been getting the SS printed. Used the files on this site, modified to reduce plastic and for ease of printing. Hopefully will get to spend some time actually working soon
    darkapollo likes this.
  7. Kevin P.
    Gun making time
    replenished inventory recently, making guns at about $8 cost each
    Everything soldered up
    elbows test fit
    next step will be magazine bending and mounting
  8. Kevin P.
    Played around with gun magazine routing, then decided to drop some components in to see how the balance and weight
    stern mags look like they will snake together down the Port side to avoid the stack of two solenoids on Starboard side
    Filled her up, most of the SS printed
    balance point at 32.5" from the bow (WL level), just about right
    25 lbs 1 oz - about 4-5 lbs below target weight, but that weight will disappear quickly
    Funny how these boats fill up quickly. The 3rd pack might have to go depending on how the weight works out
    Next will be more magazine bending, printing up mag mounts, checking gun hose routing and solenoid mounts
  9. Mad_Modeller
    Mad_Modeller Active Member
    Edmonton, Alberta Canada
    looking good, with everything so close to the sides are you going to have room to mount the inner armor mesh to protect all those goodies.
  10. Kevin P.
    Yup, no concerns about that, this boat will probably have more space than most of mine between components and internal armor - the pet-resistant dog screen has held up great on all my boats
  11. Caractacus Patt
    Caractacus Patt Member
    Granite Falls, WA
    I have a question about those LiFePo4 M cells - how do you charge them? I mean, are they semi-permanently connected, with additional wiring between cells (I think I can see extra wires coming from the terminals) to allow balance charging, or do you unscrew all the cells and charge them separately each time?
  12. Kevin P.
    They are wired as a 2s pack with the appropriate balance lead. They connect to the charger the same way any multi-cell lithium pack does. The terminals are coated in tool dip to prevent shorts, and they would only be disassembled if one cell died or a balance lead broke and needed re-soldering. I only balance charge occasionally because I keep the depth of discharge below any value of concern. Some other captains wire them up all individually which works too - many ways to skin the cat. The 2s 15Ah packs work well across all of my capital ships, with the larger ships having multiple packs wired in series, parallel, or a combination of both as needed
  13. Kevin P.
    Some gun work
    need to still bend these
  14. Commodore
    Commodore Well-Known Member
    Sunny TX
    Needs moar
  15. Kevin P.
    Nah, those corners look too tight
    Worked a lot today, got a few things done
    Mag mounts are in
  16. ZARUBA1987
    ZARUBA1987 Well-Known Member
    Tarkington Tx
    Looking good.
  17. Kevin P.
    Thanks
    Rudder factory is up and running
    printed up a vertical solenoid mount
    Prepping for internal armor
    first side down
    Beaver and darkapollo like this.
  18. ZARUBA1987
    Tarkington Tx
    What you use for the mold to pot your ESC? Can you reuse the mold?
  19. Kevin P.
    Previously I had a simple frame glued to a scrap piece of plywood that I put wax paper in to use as the potting form, now I just print up a box because it’s easier
    ZARUBA1987 likes this.
  20. Kevin P.
    Productive weekend. Stern gun aimer
    Swapped out barrel in B turret for more down angle
    Rudders ready to go - two different styles with two different pivot points. Traditional rectangle and the semi-circle version that worked well on other boats
    aft deck magnets glued with e6000
    barrel holders for sidemounts
    Dummy barrels in
    pump ready to go
    internal armor
    drive motors in
    solenoid mounts also in
    rudders drying, epoxied together
