WWII Scharnhorst (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Oct 14, 2020.
  1. daisycutter
    daisycutter Active Member
  2. Kevin P.
    Printed up some tube bending guides. There was some hose kink issues to sort out
    aluminum elbow
    Squeezed into the tube
    looks like its working (port gun was issue)
    Making a new box because of need for another servo lead
    decided to use triple xt30's for servo connections based on impact of loss of signal on the brushless ESCs. The fit is very tight so definitely need dielectric grease
  3. Caractacus Patt
    Caractacus Patt Member
    Granite Falls, WA
    I've looked for triple-plug XT connectors, but have never found them - where did you get those?
  4. Kevin P.
  5. Kevin P.
    Box sealed up (marine 5200)
    sprayed deck and superstructure
    bsgkid117, Beaver and Boatmeister like this.
  6. Kevin P.
    Super in place, glue down tomorrow. Should probably add the secondaries before ballasting. Also maybe program ESC, power the boat up, and take first cut at transmitter settings, sheet Friday, co2 lines at some point, systems check and sea trails remaining
    jstod and Beaver like this.
  7. Kevin P.
    Gun barrels in, pulled out radio and centered rudder, other small things
    will use stack as float, printing spool tomorrow to go in the hole there, will fill stack with foam
  8. Kevin P.
    Knocked out ugly spool, hopefully should work
    New box is done (need to cut off mounting tabs). programmed the pump ESC, also tested out the drive motors. Didn’t cook anything yet. The cracking point on the outboards was higher than I anticipated ( dead band), but I got them legal. It’ll be interesting to see how she behaves on the water. Also looking forward to testing hobbywing brushless ESC on drive in terms of reversal time vs hobbyking (still need to wire hobbywing up).
    Ready to start putting things in for real
  9. Kevin P.
    Did the duct tape thing. Overall it went well, but probably took 1.5 hours additional, so i think it will be awash from a time saving perspective, with small variation based on the specifics of the boat. For a long boat like that that i can't soak in the tub, the savings will probably be positive, for a smaller boat that could be soaked prior to removing sides, the savings would probably be negative. for a slab sided boat it probably would work well, this boat took longer due to stringer (2x windows to cut out)
    documenting window depth
    sheeted
    vicious p and Beaver like this.
  10. Kevin P.
    Painted
    motor shield
    Hole for wires and rib to sandwich the motor mount so it doesn’t pivot to touch the motor
    Wmemlo and Anvil_x like this.
  11. wfirebaugh
    wfirebaugh Well-Known Member
    El Paso Texas, USA
    I was wondering, What type of screening material did you use for the internal armor?
  12. Kevin P.
    Pet-resistant door screening
    Got wiring hooked up and co2 lines in
    Small things add up, 30 lbs with 2nd bottle. Bit heavier than I want so going to stick with one for now
    Balance
    center of gravity within 1/4” of planned
    Co2 lines much cleaner than wiring. Gun testing went well besides some co2 leaks that took a bit to correct. Hottest guns I’ve made to date. Grouping generally good but might have a burr in one of the barrels, I’ll have to check
    Superstructure gooped down, secondaries made up
    blocks to align stack
    wfirebaugh, Wmemlo and Beaver like this.
  13. Kevin P.
    Small things tonight. Gooped some wire holders to underside of deck rim, also showing aft superstructure mount since that piece spans two deck pieces
    grip is strong
    Battery mounts (black things in bottom)
    barrel condoms and barrel pins
    Wound about 15ft of braided fishing line around spool
    let’s hope my float passes muster!
    I sprayed the secondaries, so will glue them on tomorrow. Otherwise it’s just wrapping the wire bundles and dielectric in the connectors I think.
    also tested out Courbet tonight, everything checked out. The monitor powered on too, it will be quite the odd ball fleet going to Georgia. Still have a solid evening of gathering things for the trip and packing the car. First event of the season always takes longer to gather things that migrated over winter
    bsgkid117 and jstod like this.
  14. Kevin P.
    Gluing the secondaries down, I’ll have to figure something else out for the aft ones since they would interfere with deck hold downs (plans never arrived haha).
    Will be putting the finishing touches on pond-side! Hope it works
    Nibbles1 and bsgkid117 like this.
  15. Kevin P.
    first battle in the books, great event in GA.
    awesome shot by @Beaver
    Pre battle
    she had some teething issues and will need some changes to internals
    Damage I contributed to
    damage received, tis just a flesh wound. She took 117-15-50ish like a champ
    jstod, Wmemlo, Panzer and 3 others like this.
  16. Commodore
    Commodore Well-Known Member
    Sunny TX
    Looks splintery...
  17. Kevin P.
    Time to start the first post-battle-one refit
    Boat did ok for sea trials/battle one. Balance was a bit off so had to add weight to the bow, ended up running near max weight. Sidemounts were great, stern guns needed work - too much air flow for 1 reg, had to scale them back a bit. Boat spun after some adjustments, turns out I made rudders to the old rule size so I'll have to increase them to the current limit. outboard motors worked great, backed up straight. pump did well, might try out the 1350kV I have for a comparison to flow vs amps
    Measuring the new center of gravity with the trim weights for reference, about 1" off pre build estimate.
    moving bottle to bow, batteries slightly forward. This will allow reducing weight by a bit.
    Box probably going away, it will leave space for the three ESCs directly forward of motors. Probably will just make a new wire harness
    Once that's all sorted out, I'll have to work on the stern guns
    Wmemlo and Boatmeister like this.
  18. Wmemlo
    Wmemlo Member
    Longview, tx
    You're making me more certain that my next project will be a refit of my rookie Scharnhorst!
  19. Kevin P.
    No one deserves the pain of a rookie Scharnhorst haha. I’m certainly happy with how she did in battle one, I feel like rumors of her sucky-ness were exaggerated. Should only look up once I check several things off my improvement list.
    anyways, got a little bit on time to work on wiring. Preserved the main harness with some minor mods (octopus for aux power leads). the three ESCs will sit much closer to motors, a lot fewer connections and wiring
    need to wire up gun boards and pot
  20. Kevin P.
    Not much boat time recently, more time in last couple evenings
    found out why rudder servo stopped working
    Disappointing performance for a single event with no sinks. I used some old fashioned waterproofing on the replacement (with current products), conformal coating on the board then e6000 around all lower joints. Seemed like the weak point was the wire boot, so that had all surfaces hit with e6000.
    boards are wired up and tested, bricked the receiver and transferred settings
    got mounts in for new arrangement. Here’s a bottle mount that snaps onto the athwart ships battery I drew and printed tonight
    with bottle.
    Without bottle
    overall new layout
    Balance is much better, allowed removing a lot of trim weights. Total boat weight will be around 30.5 lbs.
    need to run new co2 lines. Planning to use the 3oz bottle for just the third triple. New rudders are in the works. Should have it at oakboro ina a couple weeks
    Boatmeister and Lou like this.
