Wyoming Class
Discussion in 'Ship Plans' started by iowaclass, Mar 12, 2017.
  1. iowaclass
    iowaclass Member
  2. KeriMorgret
    Seattle, Washington
  3. iowaclass
    iowaclass Member
    keri,
    Thanks for the recommendation but I really don't want to join another forum, I try to keep my forum membership to a minimum.
  4. SteveT44
  5. iowaclass
    iowaclass Member
    SteveT44,
    Thanks for the reply but as I have previously said, I know of the vendors and prefer not to go that route. I have found many Booklets of General Plans online for free as they are open source and do believe it should be the same case for the Wyoming Class (I just haven't found it yet).
  6. Lou
    If google didn't work and HNSA was a bust, then you are out of luck. You could pay someone to go to the national archives and scan if they have the copies.
    Good luck with this, no idea on quality.
    http://www.the-blueprints.com/blueprints/ships/battleships-us/
    If you are building her for combat, she is not the best boat. If you are wanting a scale model, I would suggest using google and join those forums for detail as the combat models are semi scale.
  7. SteveT44
    No new forum memberships and no calls to vendors? You just want scans of the original builders drawings (in high res of course) to popup first on a Google search I guess. Well good luck with that, it's not a well documented boat.
  8. iowaclass
    iowaclass Member
    Doesn't have to be "high res" - as you can see from my post about BB-57 from the National Archive online, I am fine as long as I can see the lines. BTW - there's no need to be hostile.
  9. Lou
    No one is being hostile. We generally like to help others, but as Steve pointed out it is not realistic with your parameters.
  10. iowaclass
    iowaclass Member
    I'm not trying to cause any problems - I just don't think my parameters are unreasonable, especially since so much is available online without the need to purchase.
  11. Beaver
  12. SteveT44
  13. SteveT44
    With the new rudder rule she may not be that bad. Of course, a Florida would be better.
  14. Beaver
  15. absolutek
    He'd be better off getting the plans from eBay. They look to be Ed Wisswesser(sp?) plans. The plans Strike has are Goff plans, my 3 year old can scribble a better looking plan set for less money.
  16. Lou
    He would be better off going to a scale model site and hunting down these plans. They tend to count more rivets that we do when looking at plans.
  17. KeriMorgret
    Seattle, Washington
