Building an RC Warship Videos
Discussion in 'Warship Builds' started by Kevin P., Oct 9, 2020.
  1. Kevin P.
    I've decided to put together some videos outlining the major steps of building a warship. Hopefully some people find the different form of media useful. I'll plan to update this post with the links as I post videos. Let me know if there are certain aspects you would like to see covered
    Intro / overview videos
    Tyler's video on ship classification
    View: https://www.youtube.com/watch?v=4Xy6ffsrxO8&t=3s
    Tyler's video on wood vs fiberglass hulls
    View: https://www.youtube.com/watch?v=1yQHKjL7iHI
    Building a warship videos
    Video 1 - Float test, center of floatation, model weight
    View: https://youtu.be/Bd_jetjyDqg
    Video 2 - Marking and Cutting Windows. Video covers:
    • Calculating number of ribs
    • Freeboard guidelines
    • Marking the hull
    • Roughing up inside of hull
    • Cutting windows
    • Examples of casements cut out
    View: https://www.youtube.com/watch?v=Eq4apz65hGk&feature=youtu.be
    Video 2 Part 2 - Reinforcing ribs
    https://youtu.be/Ph7OCV__eMU
    • Reinforcing ribs with fiberglass mat either before or after cutting out the hull
    Video 3 - Internal Layout. This video covers:
    https://www.youtube.com/watch?v=7oK3UkMnNDA
    • Internal layout of cruiser
    • Internal layout of battleship
    • Balancing components
    • Deconfliction
    • Tours of Radetzky and Kongo
    Video 4 Part 1 - Drivetrain component selection (placeholder)
    Video 4 Part 2 - Shafts and motor mounts - battleship. This video covers:
    https://www.youtube.com/watch?v=Rp47Y4W5Kj8
    • Shaft and stuffing tube materials
    • Shaft length
    • Stuffing tube install
    • Gears and collars
    • Gearbox install
    • Flex collet coupler shaft install
    Video 4 Part 3 - Shafts and motor mounts - cruiser
    Video 4 Part 4 - Drag shafts
    https://youtu.be/FYtf0Gg9-w4
    Video 5 Part 1 - Rudder Mount and Servos
    https://www.youtube.com/watch?v=hBX27N9doIA
    • Examples of rudder servo mounts
    • Waterproof servo selection
    • Rudder post placement
    • Rudder pivot points
    • Installing rudder post and servo mount
    Video 5 Part 2 - Rudders
    https://www.youtube.com/watch?v=aJJ8lhsZmO8
    • 3D printed rudder assembly
    • Wooden rudder assembly
    • Common rudder shapes
    Video 6 - Water channeling. Video covers:
    • Types of water channeling
    • General strategy/best practices
    • Installing waterchanneling with ultralite (two part urethane)
    View: https://www.youtube.com/watch?v=eYaMnGWkGU0&feature=youtu.be
    Video 7 Part 1 - Subdeck and deck. Part 1 covers:
    • Deck material
    • Deck thickness
    • Cross-member location
    • Tracing and rough cut of subdeck
    View: https://www.youtube.com/watch?v=4aj0ZX96LUg&feature=youtu.be
    Video 7 Part 2 - Subdeck and deck. Part 2 covers:
    • Cutting subdeck and deck
    • Fitting to hull
    • Deck fasteners
    • Epoxy job prep
    • Beginning of install
    View: https://www.youtube.com/watch?v=8d-pIGC9ntM&feature=youtu.be
    Video 7 Part 3 - Subdeck and deck. Part 2 covers:
    • Main epoxy job
    • Post-epoxy job clean up
    • sealing the deck
    View: https://www.youtube.com/watch?v=PRhac8FwUuI&feature=youtu.be
    Video 8 - Deck pieces and Barbettes
    Will's video on cannon construction
    https://www.youtube.com/watch?v=cBdEDcTQO7g
    Video 9 - Mounting Guns and Turrets
    Video 10 - Internal Armor
    View: https://www.youtube.com/watch?v=hknBGsbypLc&feature=youtu.be
    Video 11 - Pumps. This video covers:
    • pump motor selection
    • basic pump principles
    • pump mounts
    • outlet restrictors
    • outlet tubes
    • pump control
    View: https://www.youtube.com/watch?v=570BiWwm-EY
    Video 12 - Installing Shafts and Motors. This video covers:
    • Attaching props to shafts
    • Greasing stuffing tubes
    • Adding flat spots to shafts
    • Locktite
    • Installing flex collet couplings
    • Installing drive gears
    • Setting drive gear engagement
    https://www.youtube.com/watch?v=Pna1ZSvVG_w&t=6s
    Video 13 Part 1 - Electrical - design and wiring harness. This video covers:
    • Wiring planning / diagram
    • Series vs. Parallel
    • Connector types
    • Wire selection
    • Basic soldering
    • Solenoid diodes
    https://www.youtube.com/watch?v=ze8TNsS-lZA
    Video 13 Part 2 - Waterproofing electronics
    https://youtu.be/VQN9f3TbSGI
    This video covers:
    • Potting electronics in epoxy
    • Using acrylic conformal coating
    • Coating board with e6000
    Video 13 Part 3 - Waterproof box
    https://youtu.be/8ab8nqidzwo
    This video covers:
    • Using waterproof box vs component waterproofing
    • Box selection
    • Sealing wires exiting the box
    Video 13 Part 4 - ESC programming
    Video 14 - Batteries and Battery Mounts
    Video 15 - CO2 System
    Video 16 - Superstructure
    Video 17 - Sheeting.
    https://www.youtube.com/watch?v=dqn2TqOPIR4
    This video covers:
    • Applying duct tape to hull
    • Balsa preparation
    • Sheeting the boat
    • Sealing the hull
    Video 18 - Finishing Touches
    • Painting hull
    Video 19 - Sea Trials
    https://youtu.be/KLJj6jD5WMI?si=plTknVukBr3fkFYL
    This video covers:
    • Ballasting / fixing list/trim
    • Setting speed
    • Driving in straight line
    • Turning
    • Pump / damage control test
    Video 20 - Post battle maintenance.
    https://youtu.be/zbos7idO60Y
    This video covers:
    • Rinsing boat
    • Protecting electrical connectors
    • Lubricating motor bearings
    • Battery storage
    • Making incremental improvements
    Additional Videos
    Setting gun piston height - critical step for proper fast gun cannon operation
    View: https://www.youtube.com/watch?v=UokluZnSrc0&feature=youtu.be
    Bilge Keels. Video covers:
    • Purpose of bilge keels
    • Installing bilge keels
    View: https://www.youtube.com/watch?v=ONyQoCPreK4&feature=youtu.be
    Fiberglass plug and mold construction
    Fiberglass hull construction
    Turnigy radio button conversion. This video covers:
    • End to end button conversion
    • Radio wiring diagram
    https://www.youtube.com/watch?v=UncRHw0-4Xg&t=13s
  2. Beaver
    This is excellent! Thank you for taking the time to do this, Kevin. This will be an invaluable resource.
    Jack Webster likes this.
  3. Justin Ragucci
    Rockaway NJ
    Kevin this is awesome definitely something that should be pinned to the page for sure. You go into great explanation when you go from step to step. I love it.
  4. Kevin P.
    Thanks guys, glad you like it.
    New video added to post above - calculating ribs and cutting windows. Much more of a beast, 45 minutes
  5. Kevin P.
    New video added above - water-channeling. Video 3 will be internal layout, video 4 will be drivetrain, and video 5 will be rudders (focus on Fuso build). Video 7 will be deck - most footage is shot, maybe edit/publish this weekend
    Panzer likes this.
  6. Kevin P.
    Added videos on bilge keels and subdeck/deck part 1. Remaining deck videos hopefully coming shortly
  7. JRC123
    JRC123 Member
    Tennessee
    Very informative. I can’t wait to see the rest of them. Thank you.
  8. Kevin P.
    Added deck video part 2. Trying to work through the backlog in footage, current queue includes last part of deck install, deck pieces, setting gun T height, pump mount/assembly, installing shafts/motors, some gun mounting.
  9. Kevin P.
    Added last deck rim video, adjusting gun piston height, internal armor. Also added a few videos from Tyler about ship classification and wood vs fiberglass hulls
    Panzer likes this.
  10. bsgkid117
    Tune in for next episode of Bob Villa's this old boat.
    All jokes aside, extremely informative videos. Thank you Kevin for going through the effort to make these for us.
    NickMyers, Mark41 and Panzer like this.
  11. Kevin P.
    Added video on pumps
    WillCover likes this.
  12. Brandon B
    Brandon B Member
    Southern California
    Very well done, can't wait to get started on my own, and when I do, i'll be coming back here every day!
  13. Kevin P.
    I was able to finish up some videos over the holidays, I added three new ones and linked @bsgkid117 gun video
    I also hit the media limit on the post, so they are just links to YouTube
    videos added
    -internal layout
    -shaft/motor mount install for battleship
    -electrical overview and wiring
    I have recordings for several others done, I’ll try to be better at knocking them out
  14. Kevin P.
    Recent videos added:
    • Drag shafts
    • Rudder post and servo mount
    • Sheeting
  15. gunner250
    gunner250 Active Member
    Missouri
    I found these vids on YouTube last week and have decided to finally get around to my Lutzow in 2024 using these as references.
  16. pba
    pba Active Member
    dayton
    Does anyone have a file on the bismark that will print on ender size bed 220--220--235
    gunner250 likes this.
  17. gunner250
    Missouri
    Kevin P. likes this.
  18. LjWolf303
    LjWolf303 Active Member
    Payson, UT
    Great videos. Just one problem. No videos about big guns or fast guns.
  19. bsgkid117
    LjWolf303 likes this.
  20. LjWolf303
    Payson, UT
    Missing some videos that I’m struggling with.
