kit being converted for 3d printing...
Discussion in 'SMS Deutschland Kit Related' started by GregMcFadden, Oct 13, 2021.
  1. GregMcFadden
    8 pounds even, sans sheeting, cannons, and a bit o wiring. Everything else is in there.
    Lord Haw Haw and Xanthar like this.
  2. Kotori87
    Very nice. Still prototyping, or will these be available for printing soon?
  3. GregMcFadden
    Soon... I still need to go back and remove some of the "stuff" I tried from the hull. I figure people can sort out their own supports. I finally just started using tree supports with great success. super is 10oz right now... bout an ounce of support plastic I forgot to remove before I acetoned it.... so it is a bit heavier than it could be... For you, I'd be happy to start floating around test print parts. it is a bit tricky to make it work for everyone, I have taken advantage of my large printer print size on occasion.
    Anvil_x likes this.
  4. GregMcFadden
    75 round bow gun assembly barely fits.
    Xanthar likes this.
  5. GregMcFadden
    Well, time to clean up wires add armor and sheet. Everything works so far
    Panzer, Lord Haw Haw and NickMyers like this.
  6. darkapollo
    darkapollo Well-Known Member
    Carlisle PA
    Loving the rainbow dazzle pattern :-D
    Panzer and Lord Haw Haw like this.
  7. GregMcFadden
    Well, you get what is in the printer, and the girls have been choosing the colors
    WillCover and darkapollo like this.
  8. GregMcFadden
    Sans sheeting & armor, 8.8 pounds
  9. GregMcFadden
  10. GregMcFadden
    As part of my cleanup in preparation for test I stumbled across some vintage copperheads from back when they were actually round in the early 90s
  11. Commodore
    Commodore Well-Known Member
    Sunny TX
    Those were the days.
  12. Radioman
    Radioman Active Member
    Franklin Wisconsin
    Need help. How do you work with this file to get the parts to print. I have solidworks but just learning how to use.
  13. GregMcFadden
    you have to export parts of it to stl. it is set up specifically so you can merge/split up the parts as necessary. you can select one component in SW and when you export an stl, select only selected bodies in the popup box
  14. Radioman
    Franklin Wisconsin
    Thanks Greg, I have figured it out. Solidworks is something, lots to learn.
  15. Radioman
    Franklin Wisconsin
    Greg, what percentage of infill did you use?
  16. GregMcFadden
    I used progressively decreasing in fill so for the first millimeter under a top surface it was 75% by the time you're a couple millimeters down it was about 15%
  17. GregMcFadden
    And now for insane experiments with sheeting.... Hot melt glue bead laid down on hull, then monokote iron is used to iron on balsa. Seems to work well. I have some spray on heat sensitive adhesive to test for silkspan also, but that will be tested on scrap to check for penetrability...
    darkapollo likes this.
  18. darkapollo
    Carlisle PA
    Thats a pretty awesome idea! Imma have to try that when I resheet Derf
  19. GregMcFadden
    so... https://www.walmart.com/ip/SpraynBond-by-HeatnBond-Fusible-Spray-Adhesive-6-9-oz/331253634 appears to work well. I have now applied silkspan via Iron on approach as well as patches. wood is still nice and flexible (more flexible than wood with silkspan and dope actually) and holes punch rather similarly. there is a bit of an art making sure you have the correct amount of adhesive on the silkspan, but it is obvious if there isn't enough once you get used to it. soaked some in water, can't get the silkspan to pull off yet.
  20. Lord Haw Haw
    Lord Haw Haw Member
    North Carolina, United States
