Pocket Battleship Deutschland
  1. JustinScott
    JustinScott Vendor
    We should collaborate on the triple! I’d be curious what you do that’s different than the triple I’ve been testing. It’s hitting hard enough with BBs for big gun. I was already prepped to acetone vapor the latest revision which should be capable of 7/32”.
    At least that was the plan before sea trials was a disaster….
  2. Commodore
    Commodore Well-Known Member
    Sunny TX
    Looking pretty good at the moment. If you move that rudder servo forward a few inches, it should be easy to fit a standard size servo.
    JustinScott likes this.
  3. JustinScott
    JustinScott Vendor
    Yup. That’s the next step.
  4. JustinScott
    JustinScott Vendor
    I would NOT have called that "easy"!
    The servo mount is now pushed forward enough to mount a full size servo.
    - The photos below are depicting the small servo that I was using before; but you can see all the space around it.
    - To accommodate a larger servo; the servo plate will be taller to match the increased depth of the servo. I did this so I can easily change out servos by printing out different plates.
    It does make me sad to see all that space be consumed by only the rudder push-rod.
    Screen Shot 2023-04-05 at 6.13.08 PM.png Screen Shot 2023-04-05 at 6.13.54 PM.png Screen Shot 2023-04-05 at 6.14.11 PM.png Screen Shot 2023-04-05 at 6.18.41 PM.png
  5. JustinScott
    JustinScott Vendor
    Gear box time!
    I'm going to write this entry as I work; using this forum as a notepad.
    Goals:
    - I want as much flexibility as possible. Once again, I absolutely do not want to get stuck with another show stopper and unable to proceed.
    - I want to support speed increase and speed reduction gear ratios, because I don't exactly know what I'll wind up needing.
    - I want to support gears and pulleys.
    Firstly, I cut the largest gear-trench in my hull that I felt comfortable. This is to support larger prop-shaft gears and slowing the boat down with higher torque, if needed.
    The maximum prop gear which now fits is 28mm (33T/32P); which is the same diameter as my new 380 motors.
    Next, I wanted to do something a little more realistic to measure the top gear spacing. On the following thread, @Commodore recommended a set of gears as starters.
    - https://rcwarshipcombat.com/threads/what-gears-are-you-using.447253/
    I used the diameter of those gears as a rough minimum distance between the prop and the motor shaft. I then added a little extra tolerance.
    Then, I resized the motor plate, verifying actual motor dimensions against the physical unit.
    Lastly, I wanted to verify I had enough spacing for gears or pulleys. I expect that 3/4" is plenty.
  6. JustinScott
    JustinScott Vendor
    Lastly, I need a place for my ESCs & since I solder them to the motors, I want them close by.
  7. JustinScott
    JustinScott Vendor
    Next Update - CO2 Bottle, improved mount.
    The first revision wasn't steep enough & the bottle would feed liquid CO2. I also assumed the new bottles were magnetic, like the ones I had years ago... nope!
    This revision is a lot steeper, and I've support & sliced the shape of the bottle into the hull.
    Lastly, I hate bottles that fall out. So I added strap mounts too.
  8. JustinScott
    JustinScott Vendor
    Today’s update-
    I give total credit to the guys in NTXBG for this design. It was originally designed to give structure and support to the Indiana gun’s rotation fitting.
    When I saw it, I realized it could be adapted for my canister cannons!
    It is essentially an all plastic ball bearing.
    diceman42 likes this.
  9. Commodore
    Sunny TX
    Have your new motors arrived yet? Also, a 28 tooth gear on the drive shaft is sufficient, you don't need to run anything huge. It just makes alignment etc. more difficult.
  10. JustinScott
    JustinScott Vendor
    Yup the motors arrived yesterday. I rechecked all the measurements & sent the motor + aft sections to the printer tonight.
  11. Commodore
    Sunny TX
    Good luck! I might just be cooking something silly up myself. We'll see if/how it works out.
  12. JustinScott
    JustinScott Vendor
    you can’t say all that and not share!
  13. JustinScott
    JustinScott Vendor
    The thing I don't like about gears the most is the cost of them. No matter where I look, the online vendors are asking like $10-15 per gear.
    I figured I might as well try to print them & see how it does. Even if they don't hold up long, I'd at least like to have confidence in the size gear that I need to buy.
    I went with the herringbone gear pattern because the key shape will hold the gears in alignment. It’ll also sound better than spurs, which is cool too.
  14. Beaver
    Hmmm, belt drive??
  15. JustinScott
    JustinScott Vendor
    that’s my plan B if the printed gears don’t work well.
    where are you getting the belts.
  16. Beaver
    Ebay has been a pretty good source
  17. Kevin P.
    Robinson racing 48p gears are about $5 each
  18. bsgkid117
    Traxxas 32p gears @ amainhobbies.com are like $3-7 each...
    I'm all for 3d printed stuff but I have destroyed hardened heat treated steel gears in a boat, printed gears would last about 1.8 sorties. If that. Would in reality last until the first rapid forward/reverse slam or first mossing or first prop grounding while maneuvering.
  19. JustinScott
    JustinScott Vendor
    Thank you @Kevin P. - I remember using 48P back in the day and it never survived the second sortie. Not saying the plastic will hold up any better, but it's far cheaper...
    @bsgkid117 - None of those will fit the recommended 380 motors, which both have a 2.3mm shaft. I am still in my amazon purchase window so I can return them. Can you recommend a different 380 motor with a 1/8" shaft?
  20. Kevin P.
    The 48p gears were an ‘industry standard’ for a long time and have been combat proven many times over, so it sounds like an install error or something in your case. I currently have them in Courbet and radetzky both running 550’s at fast gun speeds with multiple nationals under their belt. I’ve moved away from them in anything class 4 and up for new builds because that’s about the limit I found, but for a 380 on a cruiser at big gun speeds they would perform fine. I consider drive to not be a ‘nice to have’ so personally I would go with the 48p over the printed design, buts it’s of course your build, just want to make sure relevant info from the broader combat world is shared
    bsgkid117 likes this.
